Re: Camera Setup
Probably the easiest way just to test the camera is to reformat the cRIO using the FRC cRIO Imaging Tool. That puts the default program back on the cRIO and it streams the camera back to your PC.
You can leave the cRIO formatted for Wind River, so your regular programming won't get messed up. Then use "FRC Dashboard Project" from the LabVIEW startup window and run it by right clicking on Dashboard Main.vi and clicking Run. If the camera is setup correctly you'll get the video. |
| camera setup procedure | windell747 | Programming | 2 | 31-01-2009 22:36 |
| Can't figure out the Axis camera setup... | 2829ron | Technical Discussion | 6 | 20-01-2009 13:12 |
| Setup Axis Camera - ERROR | Bruno Inácio | Technical Discussion | 2 | 16-01-2009 12:37 |
| Camera to motor setup | Windward | Programming | 24 | 18-02-2006 20:29 |
| Is the suggested Vision Camera setup ILLEGAL?! | Mr. Lim | Rules/Strategy | 37 | 20-01-2005 21:46 |
