Go to Post Publishing your code and designs = good. - MrRoboSteve [more]
  #46   Spotlight this post!
Unread 24-02-2009, 10:55
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Methods of adding ballast to underweight robots
To add to Al's pneumatic suggestions, the brass fittings can be screwed together and can add a lot of weight fast.
  #47   Spotlight this post!
Unread 24-02-2009, 10:58
It will be interesting to see teams using pennies and listing them on the BOM.
Ex. 2000 copper or copper/zinc one cent US or Canadian coins Undepreciated Cost $20.00
  #48   Spotlight this post!
Unread 24-02-2009, 12:09
Dick Linn's Avatar
no team (Synergy)
If you can find a gunshop that will loan you a bag of Tungsten shot, that is about as dense a material as you'll commonly find. Costs about $30./lb. Lead shot is much cheaper. An old bicycle inner tube partially filled with shot or old wheel weights and tied up like link sausage should be pretty easy to strap on there somewhere.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #49   Spotlight this post!
Unread 24-02-2009, 20:55
DonRotolo's Avatar
Back to humble
FRC #0832
We found (and used) a 1" square bar of bronze which weighs 0.17 pounds per inch. Last year we used about 8 pounds of it, this year about half that.
large copper wire - like 600 MCM - is heavy and relatively inexpensive. We have an 8 inch piece which weighs about half a pound, maybe more. If you know an electrician, maybe she will loan you a few feet - but give it back after the season, or pay the scrap value to them at least.
I hear small pieces of railroad track are heavy...
  #50   Spotlight this post!
Unread 24-02-2009, 21:00
MikeMascaro's Avatar
MikeMascaro MikeMascaro is offline
Fearless Leader
FRC #0888 (Robotiators)
Team Role: Driver
MikeMascaro is an unknown quantity at this point
We're using pieces of steel we had laying around as "armor plating"
The man with the red hat. Hopefully I'll see you!
  #51   Spotlight this post!
Unread 24-02-2009, 21:14
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
loads of metalshavings ... in your victors... jk
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
  #52   Spotlight this post!
Unread 25-02-2009, 09:39
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Ballast Confusion
Originally Posted by Tom Line View Post
Vaporized lead can be hazardous if you ingest / breathe it, yes. However, I have been unable to find the rule you're talking about regarding not using lead solder at competitions. Can you please cite it?
Also, I would suggest that there are many dangerous chemicals inside both the battery and the control boards (heavy metals, lead, etc). Unless you plan on somehow eating your control components and battery, they are usually benign. Having lead sealed inside your frame would hardly be dangerous - though it might make quite a mess if you managed to fracture your frame
In the safety manual they ask teams not to use lead solder at events.
Originally Posted by FRC Team Safety Manual
NEW - At FIRST events: Use lead-free solder only and solder with electrically heated soldering iron/gun only.
Wetzel
Viva Olancho!
  #53   Spotlight this post!
Unread 25-02-2009, 09:52
I had hesitated to include this in my first post, but robot rules do not prevent you from mounting unused 2009 KOP motors as ballast. Use the mounting holes and hardware meant for the motor, just tie off and insulate the wires so that they don't come in contact with any active circuitry.
  #54   Spotlight this post!
Unread 25-02-2009, 10:03
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It had been alluded to earlier in the thread, but keep in mind that ballast is a great way to move/control your center of mass. Where you place it will have a great impact, and can be used to improve robot control, improve acceleration, and prevent tipping.
Also keep in mind that this brand new weight will change your robot handling, and your drivers may have to re-learn how to drive the robot.
  #55   Spotlight this post!
Unread 25-02-2009, 10:10
Teammax's Avatar
Teammax Teammax is offline
30 Members 6 Weeks 1 Dream
AKA: Rob Cormier
FRC #1071 (Team MAX)
Teammax is just really niceTeammax is just really niceTeammax is just really niceTeammax is just really nice
Don has the same idea we did. We used 1" diameter brass rod because it is what we had around. It looks very sharp when polished up and was easy to mount pretty much anywhere we wanted. One rod runs along the back of our base and weighs about 10lbs. The other rod runs near the front and weighs about 8 lbs. In the end I would recommend this method for adding weight due to the ease of mounting and the nice look it adds.
  #56   Spotlight this post!
Unread 25-03-2009, 14:50
clueless newbie clueless newbie is offline
luddite
clueless newbie is on a distinguished road
3119's robot weighed 60 lbs. Two 27" 2" diameter steel bars (23.4 lbs each) got the weight up to 116 lbs. Ain't a thing of beauty that's for sure.
I would have preferred to mount the bars in a tray so they could roll toward the back (on start) with springs or compressed air to return them to the front. Moving an object is function of moment of inertia. And traction is a function of mass. So the rolling ballast will lower the moment of inertia and allow more power to be dumped at the start.
  #57   Spotlight this post!
Unread 25-03-2009, 15:46
Tazlikesrobots's Avatar
Tazlikesrobots Tazlikesrobots is offline
Jack of all trades...Master of none
AKA: Robert
FRC #1745 (P-51 Mustangs)
Tazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud of
Send a message via Yahoo to Tazlikesrobots
At the Dallas regional, there was a robot that used bags of cat litter for ballast. Basically it was a driving chassis with one of the kt tubs attached and two 20 pound bags of cat litter inside the tub.
They got the judges award
It is all mind over matter....If you don't mind, it does not matter.
_________________
2006 Woodie Flowers Award Recipient - Lone Star Regional
2006 Rookie All-Star - Lone Star Regional
2007 Lone Star Regional Champions
2008 Quarter-finalist - Lone Star Regional
2009 Chairman's Award & Website Award - Dallas Regional
2009 Quarter-finalist - Dallas Regional
2010 - Xerox Creativity Award & Semi-finalist - Dallas Regional
  #58   Spotlight this post!
Unread 25-03-2009, 15:59
GaryVoshol's Avatar
Cogito ergo arbitro
If you use barbell weights or free weights, make sure they can't fall off. One slipped it's zipties and fell off the frame; it immediately became a very effective anchor. The wheels had no hope of overcoming the friction of the weight.
(since 2004)
  #59   Spotlight this post!
Unread 25-03-2009, 17:19
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Originally Posted by Mike Betts View Post
If you go the "shot" route, please be sure that the "removable cap" you use is very secure. In the event that your robot tips over, pounds of "shot" spilling onto the floor will cause a very dangerous situation for referees, field reset, et cetera and will almost certainly get you disqualified...
We had this happen a few years ago at Peachtree. I think it was 2005. A team used a large container of BBs to add ballast. It ruptured. We spent the rest of the weekend picking them up Spilling a bunch of shot on the floor at the inspection station while adding it to your robot will not make you real popular, either.
Make absolutely sure that any container of shot is durable, secure, and sealed. I can promise you that any robot at 10,000 Lakes using shot for ballast will invite extra attention at inspection.
The best method I have seen so far this year for adjusting weight at the scale is to add some pieces of threaded rod to the robot, and bring a bucket of washers that fit over them. Add washers to the desired weight, and then put the nut on the rod. Use big rod, like 1", and the washers will also be big and substantial weight. If you are way under weight, bolt on some of the heavy stuff mentioned earlier in this thread to get you close. I've always been partial to barbell plates.
And the best thing I have heard of so far this year for ballast is an arbor press, borrowed from another team in the pits...
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
  #60   Spotlight this post!
Unread 26-03-2009, 01:52
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
What my team does is we take weights out of a weighted ankle band (just ask for one at sports authority or D(stupid censor)icks they will find it for you) and just drill holes in them and zip tie them somewhere safe. Its great because they come in 1 lbs increments so you can add just enough.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Ballast Confusion Paul11 Technical Discussion 12 02-02-2009 15:12
Ok serious question ringo115 NI LabVIEW 2 24-01-2009 12:58
Ballast considered extra parts? Gabe Rules/Strategy 9 12-02-2007 10:47
Extra Discussion for Picture Discussion Ianworld Robot Showcase 1 31-01-2005 01:28
Serious OI problems Arrowsmith Control System 8 10-03-2004 14:36
