Go to Post I was hoping they'd be selling robots. - Tristan Lall [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 24-02-2009, 15:27
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: CIM Hub
The set screw does fall into the keyway slot and has shaft collars on either side.
As long as we can keep it the screw tight, we should be ok. We don't have the machining capabilities to broach a hole in a timing belt pulley.
-Vivek
"we don't build robots, we build people"
Unread 24-02-2009, 16:17
Woodie Flowers Award
Bill Beatty Bill Beatty is offline
#0071 (Team Hammond)
Bill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond repute
Re: CIM Hub
You really don't need a machine shop to broach the 2mm keyway. A broach and 8mm collar is not very expensive. We gently rap the broach with a hammer to drive it through the bore. Using a hammer seems to work better than pressing the broach, particularly in steel.
Mr. Bill
Sprocket with hub or without? Vikesrock Technical Discussion 5 15-01-2008 01:14
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Hub for Wheel attachments Lavapicker Kit & Additional Hardware 5 09-01-2007 19:27
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
Connecting hub sprockets to shafts archiver 2001 18 24-06-2002 00:04
