Go to Post "Nuclear" is pronounced "nu kli Er." It is NOT pronounced "nu kU ler." When you use this pronunciation, no matter how smart you may actually be, you sound like an illiterate dolt (are you listening, Mr. Bush?). - dlavery [more]
Unread 20-02-2009, 12:31
alaskabas alaskabas is offline
None #0568
alaskabas is an unknown quantity at this point
Programing+encoders =?
We are trying to program our robot for autonomous period on the ftc bot, HOWEVER the encoders and by extension our motors wont work. How did you do it? Please respond ASAP
Unread 20-02-2009, 12:40
Blair Frank's Avatar
Blair Frank Blair Frank is offline
Writer and Alumnus
FRC #0852 (Athenian Robotics Collective)
Blair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the rough
Re: Programing+encoders =?
Would you mind going into greater detail? It's very hard to understand your problem from the question that you posed.
-Blair
Proud alumnus of Team 852, the Athenian Robotics Collective.
Pneumatics in a nutshell: Put together an elaborate series of pipes, canisters, cylinders, valves and hoses; then fill that system with highly pressurized air, and hope that it doesn't blow up in your face.
Unread 24-02-2009, 20:41
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
FRC #0706 (Cyberhawks)
reversed_rocker is on a distinguished road
its really hard to tell what the problem could be unless we get a description of the encoder application and a post of the code in question but one thing that originally gave our team some grief was that different encoders will give you different values. ex. one revolution on our old encoders was 1000 counts while on the new ones one revolution was only 250
Programing mormannoob FIRST Lego League 5 03-04-2007 14:02
4 encoders + mecanum wheels programing Smoking_Gun Programming 4 18-01-2007 23:43
Programing code teh_pwnerer795 Programming 9 12-12-2006 06:59
Programing great_one411 General Forum 2 01-02-2003 17:27
Programing pfortunejr Programming 1 08-01-2002 13:18
