Go to Post Admitted to MIT '14. FIRST is good stuff. - sparrowkc [more]
Unread 24-02-2009, 20:48
gwytheyrn gwytheyrn is offline
AKA: David
FRC #0461 (West Side Boiler Invasion)
gwytheyrn is infamous around these parts
Send a message via AIM to gwytheyrn
No outputs after image update
Sorry if this topic has already been covered, but here goes...
After realizing today that our robot was still running on an older version of the FRC labview extension (like 2.0) and cRio image (v1), I went ahead and updated them both. Too bad, now nothing works. I created a new project though the basic robot example and changed it to a tank drive. When I deploy the program, probes will show that the joysticks are being read, but the robot does absolutely nothing.
Anyone know the answer? In the mean time, I'm going back to pulling out my hair...I mean debugging
EDIT: Tried reimaging again, plugged through the router. Now it won't let me reimage with the unexpected error 15426, something about ftp transaction and 426 connection timed out. Happens after it gets to the updating cRio image step
EDIT2: Apparently the IP got reset to 10.0.0.2 somehow and we got the subnet error as from the above thread. Trying again with appropriately set IPs
Unread 24-02-2009, 22:50
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
Re: No outputs after image update
You also need to update your driver station firmware when you update your cRIO to the latest version.
Unread 25-02-2009, 00:11
AKA: David
I have the most recent driver station firmware. I got the thing to update after messing around with where things were plugged in, but it still doesn't work. Note that the joysticks are being read correctly and should be passed into the "tank drive" function, but there is no motor movement. The driver station is fine: the cRIO isn't so much.
Problems after the update?? Straberrie Programming 2 17-02-2009 07:11
Problems after 3rd update applied pheisinger FRC Control System 3 13-02-2009 22:47
Having trouble deploying after update 3.0A Pwolter Programming 1 30-01-2009 21:54
Purple Image after tryin to capture green. Code\\Pilot Programming 2 02-02-2005 16:55
Update after weekend #1: Batteries & misc. FRCOps General Forum 8 12-03-2002 13:04
