Go to Post My robot is my significant other. It makes me happy, sometimes it makes me sad, i wish it would lose some weight but it is always there for me. - rachelholladay [more]
Unread 24-02-2009, 21:03
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Using a bench power supply for cRIO
Is it safe to use a bench power supply to power the cRIO without the PD board? The power supply I will be using has the same current limits as the PD board for the 24V boost power supply.
Failing that, would a 24V DC adapter work without harming the cRIO?
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 24-02-2009, 21:14
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Using a bench power supply for cRIO
I think it's been said several times that using the cRio with a bench supply is not advised. Folks, feel free to correct me if I'm wrong.
Unread 24-02-2009, 21:25
KevinReid's Avatar
KevinReid KevinReid is offline
FRC #2609 (Beaver worX)
KevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to behold
I would be very nervous about doing it, but if you cant afford another power distro board... I guess you take your chances if required.
Good Luck, be extra safe.
Unread 24-02-2009, 21:54
Powering the PD with a bench supply is not supported. This means that it is possible to make it work, but we will not put any effort in to fixing "bugs" that occur when it is thusly powered. For example, a request that says "When powering the PD from a power supply the WiFi cuts out" will be answered with "Use a battery instead".
NI sells an AC/DC adaptor for the cRIO, but I don't think there is anything special about it. Take a look at the cRIO manual on the NI website.
Unread 24-02-2009, 23:21
Harry,
Using a bench supply for just the Crio should be OK. When you couple a bench supply to the PD and then try to feed some motors, there will be problems with drooping PD supply and thus the Crio reboots. Although you may find a high current power supply that is good to 35 amps peak like my Ham station power supply, it cannot handle the short circuit current of most motors in the KOP. The bench supply will go into current foldback or complete shutdown when trying to start one of these motors.
Unread 25-02-2009, 09:22
AKA: Harry Bock
FRC #1350 (Rambots)
Harry,
Yes, I was just planning on attaching the cRIO, not the PD board (or any other load for that matter) - I know that's a very bad idea. I've had success in previous years with attaching the previous control system to a bench supply, but I wanted to double-check to make sure there wasn't any danger of damaging the cRIO.
Any team who left the PD unit behind is braver than we are; there's no way we're going to reconnect all of our wiring after uncrating
Thanks for your quick responses!
Unread 25-02-2009, 09:48
Harry,
You should check the NI website for info on the CRIO. I seem to remember that the unit can accept anything from 19 to 30 volts and has a specified current for that range depending on the modules you have installed.
If a little care is taken in tying down the wiring prior to removal, the new PD should be a much easier pull and install than previous electrical distribution. As always, wire coding or color tagging helps.
Unread 25-02-2009, 10:00
If it is hard to use the WAGOs, you are doing it wrong. You may want to ask around the pits to find people who have mastered the technique, since it is very hard to teach digitally. In person, you can teach it in a few seconds.
Unread 25-02-2009, 11:03
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
I think he means that if you tied your wires down neatly and orderly, removing and replacing the PD board should be easy.
Eat, Sleep, Build Robots
Unread 25-02-2009, 13:13
Looking back at my post, I can see how you could have miscontrued my intent. My intent was to agree with and add to Al's comment, not to offer him advice. Offering Al advice on wiring robots is a like offering V-Neun advice on transmissions.
Al's comment was two fold:
1) Do things cleanly to save time.
2) The new PD's design will also save time.
My comment was to reinforce 2), because some teams are still having trouble with it.
BENCH POWER SUPPLY - Help! COACHTJ1688 Electrical 19 07-01-2008 16:48
Power supply for EDU-RC evan_wilson Control System 2 10-03-2007 21:58
Power Supply evit General Forum 2 06-02-2003 08:59
