Go to Post I don't resent or envy them for being strong teams; I hope we can continue to learn from them and someday join their ranks. - dsmoker [more]
Unread 23-02-2009, 21:16
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Help with Autonomous...
I'm trying to make the autonomous so it will activate 2 motors for the whole period and nothing else besides the movement of the robot itself.
The movement is something I don't know where to start with... I want it to run forward for like 10 seconds and then start spinning It's a tank drive so I only need to move one of the axis... But how do I coordinate a movement after the other :S?
Unread 23-02-2009, 23:00
Re: Help with Autonomous...
You want the robot to move at one speed and direction for a while, then change to move at another speed and direction? The sample Autonomous Independent does exactly that. It uses a clever trick to make things happen in sequence: chaining the error out of one VI to the error in of the next. The Delay and Feed VI takes care of the timing, and the dataflow inherent in LabVIEW takes care of the sequencing.
Unread 24-02-2009, 16:26
AKA: Yamil Asusta
I think you solved much of my issues Thank you a lot sir.
PS: You didn't tell me if the screenshot I posted works for keeping 2 motors on for the whole period.
Unread 24-02-2009, 19:16
Both Motor Opens are configured for the same PWM output. That right there will keep it from controlling two motors.
I can't tell from the section you posted what the loop structure is surrounding it, but I suspect the Motor Close VIs are misplaced. They should go outside everything, in the same realm as the Motor Opens (but on the right instead of the left).
You don't need to do anything fancy with timing if you just want the motors to run during the whole autonomous period. Just turn them on and forget them; the parallel drive sequence will make it so that everything inside the loop runs for as long as your Delay and Feed VIs total.
Unread 24-02-2009, 19:33
AKA: Yamil Asusta
I left them in port 1 cause I didn't remember which were the correct ones
I can't place the close out of it...:S There is a connection error with the loop that isn't the T/F
Unread 24-02-2009, 22:00
Dr. Manhattan Dr. Manhattan is offline
Atomic Reconstruction
AKA: Joe Bakke
FRC #2521
Dr. Manhattan is on a distinguished road
Send a message via AIM to Dr. Manhattan
It's odd, for some reason our Autonomous VI that was written already doesn't do the delay. I'm not sure why, but will be looking into it. If you have any thoughts it would be hugely appreciated.
need help with autonomous!!!!! billbo911 NI LabVIEW 4 31-01-2009 15:22
Help with autonomous MorbidAngel General Forum 2 11-12-2008 16:35
we need help with PWM problem in autonomous steve d Programming 7 03-02-2008 12:46
Autonomous With Camera schenkin Programming 20 16-02-2005 23:52
need help with autonomous caderader Programming 3 14-02-2005 18:25
