Go to Post Every match they would leave blue and red skid marks all over the carpet. It was like someone roadkilled a Smurf. - Koko Ed [more]
Unread 18-02-2009, 07:25
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Transparent Maps in Inventor?
On our robot we have clear Lexan panels with a bunch of decals, and some of them have irregular shapes. It would be very time consuming to create thin parts for all the decals.
I'm familiar with Autodesk 3ds Max and would not have trouble creating a texture map with all the decals on a transparent background.
Can this also be done in Inventor, or Inventor Studio?
Unread 18-02-2009, 09:24
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Transparent Maps in Inventor?
Expand the sketch that has the image.
Edit the Sketch.
Right click on the image icon in the browser and select Properties.
Select Transparency.
Whatever pixel is in the lower right hand corner will be your transparent mask color.
Use bmp for best results or second choice png. Do not use jpg as it will change the mask pixels and not give good transparency.
Use Decal command in Inventor to apply to part face(s).
Of course you may need to edit the source bitmap in a bitmap editing software like MS Paint or better.
If you have trouble figuring it out attach the bitmap image here.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 24-02-2009, 17:29
AKA: Kevin Thorp
Thanks JD. That worked great on solid materials (we could see the underlying material where the transparancy was) but not so good on polycarbonate (clear) material. The solid parts of bitmap become semi-transparent.
Unread 25-02-2009, 11:46
JD Mather's Avatar
Think of it like a real world physical decal or painted on emblem.
The decal has thickness and is in fact a part so model as a part and attach the part to the polycarbonate part.
Paint has thickness so think of dried paint as a solid part and model as a solid part and then "glue" in assembly as a "paint part" to the polycarbonate part.
That is what I had to do to "paint" the white on this semi-transparent assembly.
Attach the image file here if you need help.
Unread 25-02-2009, 12:03
AKA: Kevin Thorp
I'm sorry - I'm still not getting it.
Did you had create a model of the decal with the same shape as bitmap, then apply the bitmap "decal" to it, then attach it to the stapler assembly?
Or did you just apply the bitmap to the blue stapler part?
We tried the latter, but the decal ended up semi-transparent (even the parts we wanted to be opaque).
Unread 25-02-2009, 12:58
JD Mather's Avatar
Created a part same shape as decal to apply the decal. Then used that part placed on the transparent part.
The easy way was to Split the Faces and Thicken Offfset as surface, the Derive Component the surface to create the Decal part. Guess there was bit of work involved that might be beyond beginner level.
If you can attach your image I might be able to give more advice.
Unread 25-02-2009, 13:19
AKA: Kevin Thorp
I appreciate the help, but I think we'll just live with partially transparent decals. We're out of time and I'm pretty sure our Inventor team has uploaded their entry (or hopefully will today).
I'm more familiar with Autodesk 3ds Max, which does allow decals with transparancies to be applied to transparent objects. I was hoping Inventor had the same thing, but it's not a big deal. The rest of the robot looks great
Unread 25-02-2009, 18:52
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Something to think about for next: Maybe you could make the decals transparent in the real world so they match? It's kind of the easy fix, but might hurt you on aesthetics.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
FIRST Logo with Transparent Background? tdlrali Computer Graphics 6 18-08-2008 23:45
transparent materials and decals Daniel_H Inventor 6 08-03-2008 22:51
The Transparent Factory Pat McCarthy Chit-Chat 12 24-12-2005 01:04
Transparent Aluminum Mike Math and Science 16 24-10-2005 23:28
Making .gif backgrounds transparent Ashley Weed Computer Graphics 17 28-01-2004 18:08
