Go to Post Please think before you speak. - Cory [more]
Unread 21-02-2009, 16:27
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
recieve data from cRIO
We have a custom dashboard (written in C# .net or VB .net) and it is supposed to receive the packets coming from the DS on port 1165 of type UDP. we have the cRIO running the following program based off the dashboard data example:
void RobotMain()//so it executes even if disabled
		Dashboard &dashboard = m_ds->GetDashboardPacker();
		while (true)
			dashboard.Printf("It's been %f seconds, according to the FPGA.\n", GetClock());
			dashboard.Printf("451!|distance=2|flywheel=%f|!451\n", 1);//our custom packet of data
			dashboardDataFormat.PackAndSend();
			Wait(0.02);
and we have recieved on our custom dashboard... nothing, we changed the dashboard.printf to regular printfs and still nothing
here is the .net code in C#:
/*init function*/
	UdpClient cRIO = new UdpClient();
	cRIO.Bind("10.4.51.5",1165);
/*end init*/
/*in the start button click*/
	IPEndPoint ipend = new IPEndPoint(IPAddress.Any, 1165);
	this.textBox1.Text = cRIO.Recieve(ref ipend);
//*end button*/
and the code pauses and never recieves anything from port 1165, I tried out wireshark, and tons of packets are coming in, but I get nothing, what are we doing wrong?
Watchdog.Kill();
Unread 21-02-2009, 21:00
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: recieve data from cRIO
Here is the applicable code from my dashboard. It uses async calls so its a little more complicated.
    Sub BeginGetDataAsync() Implements IDashboardClient.BeginGetDataAsync
        _listening = True
        _client = New UdpClient(DS_TO_PC_LOCAL_PORT)
        _client.BeginReceive(AddressOf Me.GetDataAsync, Nothing)
    End Sub
    Sub GetDataAsync(ByVal result As IAsyncResult) Implements IDashboardClient.GetDataAsync
        Try
            Dim endPoint As IPEndPoint = Nothing
            Dim bytes = _client.EndReceive(result, endPoint)
            ParseBytes(bytes)
        Catch ex As Exception
            Throw
        Finally
            If Listening Then
            End If
        End Try
    End Sub
Eric Haskins KC9JVH
Unread 24-02-2009, 21:40
byteit101's Avatar
Thanks! now we can see something, it looks like ?M? for each packet, and changes to variations of that, ?p? ?r? ??? etc... changing the encoding changes the ? to other chars, but it looks weird (wiresharks verifies that our custom packet works, and looks normal there)
Watchdog.Kill();
Unread 25-02-2009, 19:25
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
You are awesome.. that's Visual Basic?
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 25-02-2009, 20:13
byteit101's Avatar
Unfourtunatly, yes(I am a C# person). But fortunatly, I know Visual Basic
Watchdog.Kill();
Unread 25-02-2009, 21:52
AKA: Eric Haskins
If you're just trying to get the printed strings, you'll need to do some data processing. Here is some code which should work, and I'm leaving it in VB.net just to irritate you C# bigots.
        Dim reader As New BinaryReader(New MemoryStream(data))
        reader.ReadBytes(26) 'Skip the automatically sent data (team number, battery, DS in/outs, etc.)
        SequenceNumber = reader.ReadByte()
        Dim printedString = New String(Text.Encoding.ASCII.GetChars(reader.ReadBytes(reader.EReadUInt32())))
        Me.PrintedString.Add(printedString)
        Dim errorString = New String(Text.Encoding.ASCII.GetChars(reader.ReadBytes(reader.EReadUInt32())))
        Me.ErrorStrings.Add(errorString)
        Dim dataSize = reader.EReadUInt32()
        Dim userData As Byte() = reader.ReadBytes(dataSize)
BinaryReader.EReadUInt32 is an extension method on BinaryReader since I had issues reader UInt32s from the robot. Here is the extension methods file.
Imports System.IO
Imports System.ComponentModel
Imports System.Collections.ObjectModel
Imports System.Runtime.CompilerServices
Public Module BinaryReaderExtensions
    <Extension()> _
    Public Function EReadUInt32(ByVal reader As BinaryReader) As UInt32
        Dim bytes = reader.ReadBytes(4)
        Return bytes(0) * 255 ^ 3 + bytes(1) * 255 ^ 2 + bytes(2) * 255 ^ 1 + bytes(3)
    End Function
    <Extension()> _
    Public Function EReadUInt16(ByVal reader As BinaryReader) As UInt16
        Dim bytes = reader.ReadBytes(2)
        Return bytes(0) * 255 ^ 1 + bytes(1)
    End Function
End Module
Eric Haskins KC9JVH
Unread 02-03-2009, 20:54
byteit101's Avatar
Thanks, but i figured it out:
(in C#.net just to irritate you VB bigot)
buffer= client.Receive...
string endresult = "";
foreach (byte databit in buffer)
    endresult+=((buffer==0)?"":((char)databit).ToString());//I love () to make sure thigs execute as i want (as well as ; semicolins;)
textBox1.Text+="\n"+endresult;
the problem is it was sending something like this:
?hs\0546d\0jos\0MYDATAHERE\0jsfjnn\0
and it cut off after the \0 (or null (buffer = 0) (Nothing for you VB bigot))
i just had to set a breakpoint, see the data, and realize what was happening (the string was being chopped up!);
Watchdog.Kill();
Unread 06-03-2009, 23:59
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Something very useful for feedback is the ability to write to the LCD of your DriverStation: http://thinktank.wpi.edu/article/144
Unread 07-03-2009, 07:48
byteit101's Avatar
but can you provide moving green and pink targets on the screen of it, while at the same time using a "taco-meter" (a meter looking like a taco, don't ask) to display the speed of another thing, a distance to target bar, and a timer for teleop and auto on the LCD? (we think not. plus, we have our dashboard working)
Watchdog.Kill();
Unread 07-03-2009, 16:37
virtuald's Avatar
RobotPy Guy
All that is great, as long as you have a laptop around.
Data delay between Crio and DS Tom Line NI LabVIEW 9 17-02-2009 08:40
Capture Data from the cRio goodsky Programming 2 13-01-2009 21:27
Sending data from RC to OI Nathan Programming 7 03-02-2008 22:32
Did we recieve MS Front Page from FIRST Mr.G Website Design/Showcase 2 28-01-2006 15:12
Programming Vex Starter Kit To Recieve From Serial Port firetrap FIRST Tech Challenge 0 26-09-2005 17:27
