Go to Post In the end any amount of time can work, just be smart about how you use it. - Jay O'Donnell [more]
Unread 24-02-2009, 21:34
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Reimaging the cRio Issues there are no cRio devices on the subnet
Ok so here is a problem that is new to me.
Im helping another team program their robot and we go to deploy the code. it builds it deploys, but then nothing happens. I check all the connections, run through the code to make sure things are correct, notice that the voltage is at 00.00V on the DS( they dont have a jumper on slot 1), how ever on our robot we were able to run just fine like that.
Any way I go to re image it and make sure that the run at startup is checked. while I'm doing that it errors out that it cannot find any cRio device. I recheck several times eventually directly connecting the robot to the laptop and assigning a static IP to the laptop. When I rebooted the robot it would connect and start to deploy the new image but then would error out and say that there are no cRio devices on the subnet. I click ok then it goes back to not being able to find any cRios Can any one suggest what might be going wrong here?
Ive recheck the Ip address ( laptop 10.27.43.6 and the Crio 10.27.43.2)
EDIT
I have checked that on the laptop only the wired connection is on.
edit 2
ok after reading more threads I think it might be an issue with the ethernet cable( Im not sure if were were useing the crossover cable or not)
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 24-02-2009, 22:37
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Reimaging the cRio Issues there are no cRio devices on the subnet
EDIT
edit 2
The easiest way to do this is to connect the laptop to the DS and the cRio to the other port on the DS. Make sure you are using port #1 on the cRio. That should do it if the details you listed above are correct.
Unread 25-02-2009, 23:41
jgraber jgraber is offline
jgraber is just really nicejgraber is just really nicejgraber is just really nicejgraber is just really nice
EDIT
edit 2
Edit 3: It worked after turning off the firewall on the PC......
cRio keeps on staying red on the lab view conection test all other 4 lights are green bio hazard NI LabVIEW 2 11-03-2010 16:48
Problems reimaging cRIO ravena Technical Discussion 13 17-02-2009 20:19
cRio, ethernet, and DS issues .. (was: HELP!!!!) tomy FRC Control System 5 13-01-2009 21:25
Who is Programming the cRIO with C++ and what success are you having? Wayne C. Programming 20 01-01-2009 16:48
cRIO interrupted during reimaging rsisk FRC Control System 23 21-12-2008 22:41
