Go to Post I just think the teams that will be winners will have a higher score then us :) - Kyle [more]
Unread 26-02-2009, 00:58
Re: Basic Framework
The watchdog adds a safety element to the outputs on the robot. The watchdog you are feeding, referred to as the user watchdog should be fed in the code that updates the motor speeds. That way if that code stops running for some reason -- logic error, breakpoint, infinite loop, etc. -- then the motors will turn off if not fed in 0.5 sec rather than keeping their old values and probably running into the desk/wall/person.
Greg McKaskle
Basic Robot Framework JimC2550 Electrical 1 14-02-2009 21:09
CRio Framework Shadow_Cat NI LabVIEW 1 13-02-2009 21:18
Camera on basic framework Arcre NI LabVIEW 2 11-02-2009 04:17
FRC Framework Guide Jon236 FRC Control System 0 17-11-2008 18:18
Robot Framework lord Purity Pneumatics 3 21-01-2007 15:57
