Go to Post If full body suits can be made to fit properly, why do we have so many robots with saggy bumper covers? - GaryVoshol [more]
Unread 26-02-2009, 20:11
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: Macbooks aren't the only Unibody Construction
Very nice gearboxes, compact and simple. I'm a little confused though... Isn't your robot finished already? Are these upgrade parts, or perhaps for another team?
Unread 26-02-2009, 22:38
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
A robot is never truly finished - there's always something that can be upgraded, something that to be designed better, faster, stronger.
In this case, these transmissions are going to replace two Globe motors currently powering our polycord elevator which brings balls up to the shooter. Don't get me wrong, the Globe motor powered elevator works just fine right now without any problems, but we can only fire about 2.5 balls/sec right now. With these new transmissions powered by a single FP motor, we'll be able to get 8-10 balls per second to our shooter, with a net change in robot weight of -0.9 pounds.
The three gearboxes include one for competition robot, one for practice robot, and one for a spare that will probably be assembled with a Lexan (as opposed to aluminum) cover to have in the pits to show people. The gears used in the transmission are from the first two stages in the KoP FP gearbox. I couldn't think of an elegant way to mount one of the KoP FP transmissions while outputting through the second cluster shaft with a cantilevered load, hence the design of this.
Previous revision: (on almost completed practice robot)
New revision:
And the outer plate (the pockets are on the inside of final assembly)
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-02-2009, 01:04
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Great Job Art, really innovative. Thinking about making some plastic version of these.
R.C.
MadTown Robotics Team 1323
Unread 27-02-2009, 01:40
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
What was the run time for one of those?
2001-2004: Team 100
2006-Present: Team 254
Unread 27-02-2009, 02:26
AdamHeard's Avatar
Lead Mentor
Just curious.
What's the weight difference to an optimized design with standoffs?
I imagine at this point it doesn't matter, and the reduced number of parts outweighs it as you were already underweight (iirc).
Unread 27-02-2009, 11:34
artdutra04's Avatar
Sadly, no where near as fast as I originally wanted. I had to run these on a TM-1, as the VM-3 and VF-4 were both already being used. It ended up being a little over an hour for each one on the TM-1, mainly limited by me manually slowing down the program to 4000rpm and 40ipm to avoid throwing chips and coolant everywhere (which it still did). Also, if I was going to do this again I'd optimize the CAM toolpaths, as my software added some dumb things in there that just wasted about 15 minutes doing nearly nothing. I would have loved to do this on the VF-4 at well into a triple digit ipm feed rate, with much faster rapids, and nearly instantaneous tool changes.
Edit: Also, if I make these again I won't be as lazy. The only two three end mills I used were a 1/2" flat carbide, 1/2" ball carbide, and 3/8" chamfer. It would have been nice to also add in there a 1" carbide flat end mill to hog out the pockets faster, but that a: would have been pretty scary at full force in a TM-1, and b: I would have had to walk across campus to the other machine shop to borrow another tool holder. ;-)
Originally Posted by AdamHeard
Just curious.
The unibody transmission bodies shown here weigh 5.44 ounces. Before I designed this, I did a plate and standoff design using 1/8" plate and 3/8" aluminum hex standoffs, which actually ended up being 1.6 ounces lighter. However, when I added 1/16" polycarbonate side shields to it along with a few #4/40 screws to hold it in place, the difference was essentially nothing.
The side shields were somewhat necessary in that this transmission is mounted right near one of the handles added onto to the robot to act as a safe lifting point, and also only a few inches away from the cRIO. Adding an ounce or two of shields is way easier than filling out the mountains of paperwork for that one impatient person to stick their arm into the robot reaching for who knows what only to have their fingers meet up close and personal with a gearbox.
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-03-2009, 21:54
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
First, let me say your gearbox is really cool! If we had that kind of machining capabilities in-house we'd probably do the same. Since we don't, and value our sponsor's precious machine time, this is what we came up with (which is why I asked this) - not sure you'd consider it elegant, but it sure worked
The last stage of the gearbox was removed, the case was reduced to acomodate only two stages and dremeled to pass the chain through. That way, the shaft which supports the second stage gears (and now this sprocket as well) is fully supported, not cantilevered.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unibody/Monocoque Construction Sam N. Technical Discussion 26 18-06-2007 15:09
pic: This is what happens when the parts aren't in. RoboDriver1718 General Forum 4 23-01-2007 09:03
pic: The only two Poof balls left in NH.... Andy Grady Extra Discussion 9 09-01-2006 07:36
pic: And it's only the first day... CD47-Bot Chit-Chat 8 17-01-2004 20:21
Aren't you tired of seeing this woman? Joe Johnson General Forum 30 18-01-2002 12:40
