Go to Post If something on your robot isn't working, then why don't you take the responsibility to fix it? Isn't that what being a TEAM is all about? - dlavery [more]
  #91   Spotlight this post!
Unread 22-02-2009, 12:48
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: how many people have had failing jaguars
2809, had 2/4 failed Jaguars in our testing... not a good track record so far. We sent both back to the company so they can determine the issues with the Jaguars, I hope everyone who had one fail on them did the same.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
  #92   Spotlight this post!
Unread 22-02-2009, 13:31
nomad725's Avatar
nomad725 nomad725 is offline
Lead Mentor/Drive Coach
AKA: Santesh Shah
FRC #4954 (4-H Palindrome Robotics)
nomad725 is a jewel in the roughnomad725 is a jewel in the roughnomad725 is a jewel in the roughnomad725 is a jewel in the rough
Send a message via AIM to nomad725
ours was not going backwards nd we looked over everythin nd all the wires were fine then one of the jaguars started to smoke and almost caught on fire...jus becuase tht happened our team decided to stick with the vectors
  #93   Spotlight this post!
Unread 23-02-2009, 12:01
utlinebacker's Avatar
utlinebacker utlinebacker is offline
AKA: Scott Emley
no team (Texas Instruments)
Team Role: Marketing
utlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud of
If you are participating in a regional event this week, please look for us and say hi! We’d love to meet with you and learn about your experiences with Jaguar. We’ll attempt to drop by each team pit and introduce ourselves.
Regional Event:: Luminary Micro Advisor
Washington, DC:: Brian Kircher & Scott Emley
Cleveland, OH:: Dave Wilson
Manchester, NH:: Kyle Norman
Trenton, NJ:: Paul Jordan
Traverse City, MI:: Tom Fedorko
Oklahoma City, OK:: Scott McMahon
Kansas City, KS:: Joe Kroesche
Chicago, IL:: Bobby Bradford
Here is the weekly status as of Friday (Feb 20th) evening:
Since November, we have received 88 reported failures that we have immediately replaced. Here is a pareto of the complaints:
• DOA:
- Neutral LED – 7
- PWM Missing – 3
- PWM function – 10
• Reverse only – 32
• Forward only - 1
• No voltage on output – 6
• Incorrect output voltage - 4
• Stopped working – 17
• FET melted - 2
• Other – 6
Of those 88 reported failures, we have only received 42 units back to us (still less than half) – which we have analyzed. Here is a pareto of the analyses:
• Flash not programmed – 2
• Customer-induced EOS – 3
• Gate driver U6 failed – 29
• 5V regulator failed – 3
• Missing PWM connector – 3
• Other – 2
We’re hoping we’ll receive more failed units back now that the ship deadline has passed.
My echoing reminder: If you have experienced a failure, PLEASE contact us at support@luminarymicro.com. When you do, PLEASE provide us as much information about your failure as possible (see my questions list here: http://www.chiefdelphi.com/forums/sh...0&postcount=57 – and send us pictures of your system, which are exceptionally helpful for us in understanding your use model). Finally, if you do receive an RMA replacement unit, PLEASE ship us the Jaguar that is giving you trouble. As you can see from above, we have still received only about half of all RMAs we have issued, and ideally, we’d like the opportunity to analyze every failed unit.
Good luck at regionals!
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
  #94   Spotlight this post!
Unread 23-02-2009, 13:44
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
• DOA:
- Neutral LED – 7
- PWM Missing – 3
- PWM function – 10
• Reverse only – 32
• Forward only - 1
• FET melted - 2
• Other – 6
• Other – 2
Regards,
Scott
That seems like a lot of Gate Driver failures. Is there a problem with a design or the quality of the components used?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
  #95   Spotlight this post!
Unread 23-02-2009, 17:05
Sovietmagician's Avatar
Sovietmagician Sovietmagician is offline
AKA: Ariel Eisenstadt
FRC #0694 (Stuypulse)
Sovietmagician is an unknown quantity at this point
We were going to use jaguars then all of a sudden one shorted out so we switched to victors and have had no problems at all.
Shhhhhhhh... the code is compiling
  #96   Spotlight this post!
Unread 26-02-2009, 23:05
ruhiyyeh ruhiyyeh is offline
FRC #2022
ruhiyyeh is an unknown quantity at this point
We've been having quite a few problems with our jaguars for our drivebase. We had two coupled cim motors, and one motor's jaguar failed (we noticed the smell and the fact that one motor was hot while the other was cold). That was replaced a couple times, until we borrowed a jaguar that worked. Then the jaguar for the other motor seemed to have problems, though at least it didn't smell burnt. On the field, we noticed that our bot would start off fine, then begin to stop and start. It would get slower over time. We thought that it might be because the jaguar was getting too much current and then failing for a moment, causing the other jaguar to fail in return. We figured this caused a cycle of jaguars failing repeatedly, causing our robot to be slow when only one had failed, and stop completely when both had.
So we replaced them with victors. Last I heard, one of the victors had burnt out, possibly because it couldn't handle the current.
All our other jaguars and victors work perfectly. Our batteries were freshly charged, and I made sure that the pwms were in the right orientation.
  #97   Spotlight this post!
Unread 08-03-2009, 03:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
A Jaguar failed on our machine today during the Oregon Regional semi-final.
Not happy.
--Madison--
...down at the Ozdust!
  #98   Spotlight this post!
Unread 08-03-2009, 03:32
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Not happy.
Dang Madison, that sucks. Any suggestions on what to do in order to avoid jags from killing each other. BTW, totally random but today I volunteered and reffed at a FTC comp and daisy chaining speed controllers was pretty cool. Totally random but just like to bring the CAN feature up.
R.C.
MadTown Robotics Team 1323
  #99   Spotlight this post!
Unread 08-03-2009, 10:05
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Sounds to me like your CIMs are drawing more than 40 AMPs. That will cause your snap action breaker to trip and then reset. Since it's a thermal driven device once it trips it will trip again quicker and stay tripped longer each time.
___________________
- Tennyson, Ulysses
  #100   Spotlight this post!
Unread 08-03-2009, 11:14
Remember that when the Jaguar goes into fail mode, there is a three second delay after the failure point has been removed. It is unlikely that the field conditions this year can cause over current so it is likely something else. Improper transmission assembly, bad alignment on shafts, too much chain tension, loose hardware, etc.
  #101   Spotlight this post!
Unread 26-03-2009, 21:24
Bill Tompkins's Avatar
Bill Tompkins Bill Tompkins is offline
LRI/MAR Board of Directors/Engineer
AKA: Bill Tompkins
FRC #1279 (Cold Fusion)
Bill Tompkins is a splendid one to beholdBill Tompkins is a splendid one to beholdBill Tompkins is a splendid one to beholdBill Tompkins is a splendid one to beholdBill Tompkins is a splendid one to beholdBill Tompkins is a splendid one to behold
Two jaguars died. Both the same problem, burned out in one direction only.
Bill
  #102   Spotlight this post!
Unread 26-03-2009, 22:24
clueless newbie clueless newbie is offline
luddite
clueless newbie is on a distinguished road
Team 3119 lost one Jag during build testing and our spare (reverse but no forward) during the games at Wayne State.
We're a rookie team with no funds --- (hey, we're doing good --- we own two screwdrivers and a "made-in-China" 1/4" drive ratchet set!). We got a teacher to put up $74 just so we could continue competing! Fortunately it paid off --- we made the semi-finals!
I certainly hope we can RMA the dead ones!
  #103   Spotlight this post!
Unread 26-03-2009, 22:35
Carmine Rizzo Carmine Rizzo is offline
FRC #0075 (RoboRaiders)
Carmine Rizzo is just really niceCarmine Rizzo is just really niceCarmine Rizzo is just really niceCarmine Rizzo is just really nice
Ours failed in the last match of the qtr finals in Jersey.
  #104   Spotlight this post!
Unread 27-03-2009, 19:14
Oblarg Oblarg is offline
AKA: Eli Barnett
We've wired them backwards and had them die. We've also had one or two spontaneously die with no noticeable cause.
I think we set a new team record this year for dead speed controllers. 4 victors and 5 jaguars, I think.
"The breakfast of champions!"
  #105   Spotlight this post!
Unread 27-03-2009, 19:36
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
We had another Jag die at FLR in week 2. Our bot took a hard hit on the side. Immediately after the hit, we had no movement from that side. The rep on site would have RMA'ed it immediately if he had more Jags with him at the competition.
How many teams had router problems? darkember Technical Discussion 8 31-01-2009 21:22
How many people like bumpers? diesel Rules/Strategy 53 24-01-2008 15:30
How many people like bumbers? diesel Rules/Strategy 3 18-01-2008 17:34
How many people get on CD at school... Ashley Christine Chit-Chat 37 21-06-2005 13:14
how many of u actually used the stacker if u had one? HolyMasamune General Forum 21 14-04-2003 13:12
