2009 Team 1511 LabVIEW Scouting Database
Here is version 1.0 of the 2009 Scouting Database.
2009 Team 1511 Scouting Database This database is intended to be used by any FIRST teams interested in recording match data on teams during practice, qualifying, and elimination rounds. The database is relatively simple consisting of a configuration menu, submission menu, retrieval menu, and new this year a Pit Scouting Menu. Examples of these menus are attached in the picture files. There is also a robot picture program so you can take the pictures of teams robots and easily bring them up in the retrieval menu. The database can be networked to multiple computers to allow the scouting of 6 teams simultaneously during the match. As long as all computers look in the same directory location to store files. This can be setup in the config menu. This year I have removed the dependency on MS Excel. Scouting data is written into text files that can be opened with Excel, Wordpad, or Notebook if desired. Another feature is automatic team list generation based on what event you are at. The automatic mode on the submit menu is not complete but should be for the next revision. Both the installer for the application and the source code are included in the zip file. Feel free to look through the source code written in LabVIEW 8.5.1 and modify for your own usage. I will be making new updates such as pulling Twitter match info and a statistics summary spreadsheet maker. If you have any feedback or questions please let me know. |
Re: 2009 Team 1511 LabVIEW Scouting Database
And here I thought this had to do with the Scouts update in Team Fortress
Seriously Larry - great job on this. I know how hard you and the programming team worked to get this out the door. It was fun working on twitter feed with you. Hopefully the next version of labview will have better RSS support. |
I am having a problem with the config page. It keeps saying:
"Error 7 occurred at Open File+.vi:Open File" Possible reason(s): LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer. Any reason why. I just ran the installer and left the default place. Andrew Ebert |
In the meantime try to create a folder in the root directory called TeamData. Do this if the directory already doesn't exist. Also could you provide me with the default path that came up on your computer? Thanks! |
First uninstall the program under add/remove programs in control panel. Then reinstall the program but change the install path to: C:\Program Files\Team 1511 Scouting Database\V1.0\ Once that is complete navigate to that location and delete everything in the directory. Then Download this zip file here Next unzip the contents and place them in your Program Files Directory. The new unzipped files should have the following executable path and folders. C:\Program Files\Team 1511 Scouting Database\V1.0\Team 1511 - 2009 Scouting Database.exe C:\Program Files\Team 1511 Scouting Database\V1.0\data C:\Program Files\Team 1511 Scouting Database\V1.0\PitData C:\Program Files\Team 1511 Scouting Database\V1.0\Robot Pictures C:\Program Files\Team 1511 Scouting Database\V1.0\TeamData C:\Program Files\Team 1511 Scouting Database\V1.0\TeamLists Sorry for the mistake when I get a chance I will fix the installer file so that it puts everything in the right directory structure. Thanks! |
#7
Larry,
This is really sweet. Which parts of the RSS are you having problems with? -Danny |
#8
Just curious what "ninja" maneuverability is.....and what the other choices are!
#9
If I tried to put the address for the RSS feed into the Datasocket Read it would pop up a error. It seamed to open the link ok but as soon as I tried to do a read it would error. I wonder if my data type is incorrect. I was just using a string value but maybe it needs to be something else. Any ideas? Thanks, Larry |
#10
Other values are more generic. Poor Fair Good Great |
#11
New Version 1.1!
Here is a new version of the database. Team_1511_2009_Scouting_Database_V1.1_Installer-Source.zip This version fixes the installer issues that were in the previous version. It should allow users to install wherever they want but to be honest the default should work best. Please provide feedback if anything needs improvements. Thanks! ![]() |
#12
Great job.
Just wondering how do you check the pit scouting information? |
#13
The pit scouting file is located in the base directory of the application under the PitData folder. For example: C:\Program Files\Team 1511 2009 Scouting Database\V1.1\PitData Last edited by Larry Lewis : 01-03-2009 at 22:03. Reason: Forgot to put something in post |
#14
i got 404'd trying to open it.
#15
Interesting. I just tested the link and it seemed to work fine. Could you give me any more details on what error you saw?
| paper: New Scouting Database from Team 2834 | Ed Law | Extra Discussion | 232 | 08-03-2016 10:54 |
| 2008 Team 1511 Scouting Database | Larry Lewis | Scouting | 22 | 19-03-2008 19:21 |
| Team 166 Scouting Database | Dan Petrovic | Scouting | 2 | 12-03-2008 21:10 |
| 1511 LabVIEW Scouting Database Release | Larry Lewis | Scouting | 7 | 02-08-2007 15:18 |
| Team 48's Scouting Database | Shelley_delphi chick | Scouting | 11 | 28-05-2002 02:14 |
