Re: I can't build or deploy! Error 6?
Are you running Vista?
If so right click on the LabVIEW icon if you have it on your desktop, and choose to "Run as..." administrator. It just looks like you don't have full administrator privileges. It also looks like you need to set your cRIO's IP address correctly RT CompactRIO Target (0.0.0.0) Last edited by Mark McLeod : 27-02-2009 at 14:21. |
| Run works but build&deploy doesn't | program1 | NI LabVIEW | 3 | 03-02-2009 22:32 |
| LabVIEW Woes: Build/Deploy time too long?! | leftylink | NI LabVIEW | 7 | 27-01-2009 21:52 |
| Can't Deploy All of Project to cRIO | MachineSMMC | NI LabVIEW | 2 | 15-01-2009 18:41 |
| Build Error S.O.S. | TimeOut | Programming | 2 | 10-02-2006 00:10 |
| Build Error | Chris.Steimel | Programming | 13 | 26-01-2005 17:44 |
