Go to Post The game hint is never late. Nor is it early. It arrives precisely when it means to. - Oblarg [more]
Unread 27-02-2009, 14:10
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
I can't build or deploy! Error 6?
Can anyone help? When I try to build or deploy our code we get the following error-
Error 6 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Generic file I/O error.
C:\Program Files\National Instruments\LabVIEW 8.5\resource\plugins\NewDialogFiles\ProjectWizards \FRC\FRC Templates\builds\FRC cRIO Project\RT CompactRIO Target (0.0.0.0)\FRC Basic Robot Deployment\c\ni-rt\startup\NI_FPGA_Interface.lvlib_NIFPGA System
Unread 27-02-2009, 14:18
Re: I can't build or deploy! Error 6?
Are you running Vista?
If so right click on the LabVIEW icon if you have it on your desktop, and choose to "Run as..." administrator.
It just looks like you don't have full administrator privileges.
It also looks like you need to set your cRIO's IP address correctly
Unread 27-02-2009, 19:56
FRC #2147
Within our code the RT CompactRIO Target (10.21.47.02) is set to our team's IP address.
I did notice that part of the file name that is associated with the error message is RT CompactRIO Target (0.0.0.0).
C:\Program Files\National Instruments\LabVIEW 8.5\resource\plugins\NewDialogFiles\ProjectWizards \FRC\FRC Templates\build\FRCcRIOProject\RT CompactRIO Target (0.0.0.0)\FRC Basic Robot Deployment\c\ni-rt\startup\NI_FPGA_Interface.lvlib_NIFPGA System
Could this be part of the problem?
Unread 27-02-2009, 20:05
Are you using LabVIEW update 3? I think the build path you have is from an older version.
Unread 27-02-2009, 20:13
FRC #2147
I think it may have something to do with file naming. The error message indicates that the file that is set in the "Local destination directory" from the FRC Basic Robot Deployment Properties is the cause. We did have earlier issues when we renamed and moved our original project.
What file path shoul the "Local destination directory" point to?
Unread 27-02-2009, 21:13
Don't blindly reinstall. If it's a pathname change issue, the fix is to find the spot in the build specification that points to the incorrect path and to modify it to point to the proper one.
Make a new project and look at its build spec for an example of what the existing project needs to look like. We had to do that when we moved our code from a Windows XP system to a Vista one, and the "My Documents" folder location is different.
Unread 27-02-2009, 21:30
FRC #2147
I think I found the correct filepath. I made the change tried to build and got a lot of file collision warnings. I know from reading other threads that seems to be normal..right? At the end of the build it did say the build was complete.
Now, of course the robot shipped so I can't make sure it will deploy..but..when we get access to our robot again we will need to right click on "FRC Basic Robot Deploy Properties" then chose "run as startup"...right?
Unread 28-02-2009, 07:00
I believe the 0.0.0.0 needs to be set in the properties dialog for the cRIO. Right click on the cRIO item in the project window and put the correct IP in. This normally gets filled in by the new project wizard, but this is how to change it later. It is also possible that this is the name of the cRIO in the project and in that case, you change it in the same place.
Greg McKaskle
Unread 28-02-2009, 10:54
What version does it show when you got to help -> About FIRST Robotics Competition Software?
Run works but build&deploy doesn't program1 NI LabVIEW 3 03-02-2009 22:32
LabVIEW Woes: Build/Deploy time too long?! leftylink NI LabVIEW 7 27-01-2009 21:52
Can't Deploy All of Project to cRIO MachineSMMC NI LabVIEW 2 15-01-2009 18:41
Build Error S.O.S. TimeOut Programming 2 10-02-2006 00:10
Build Error Chris.Steimel Programming 13 26-01-2005 17:44
