Go to Post To offer an opinion is fine, to demand that others adhere to your opinion is laughable. - JVN [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 27-02-2009, 22:28
aybose aybose is offline
FTC #2485
aybose is an unknown quantity at this point
Exclamation [FTC]: Changing the name on the NXT brick
So I understand that we need to change the name on our NXT brick to our team number. How do I do this? Right now, it is set at the default, "NXT". Thanks!
(a QUICK response would be appreciated, competition is kinda tmmrw, hehe, procrastination FTW.)
Unread 27-02-2009, 22:42
brad brad is offline
FTC #0265
brad is an unknown quantity at this point
Re: [FTC]: Changing the name on the NXT brick
If you're using RobotC, simply go to "Link Setup" connect your brick via USB, then click "Rename NXT". After this, type in your team number, and you are good to go.
Unread 27-02-2009, 23:27
FTC #2485
...I'm using LabView. Thanks though.
Unread 03-03-2009, 08:04
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
If you are using LabView:
Go to Tools menu
then nxt module
then nxt terminal
click on find nxt
in the name block type new name
click on rename
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
Unread 04-03-2009, 16:11
paragon571's Avatar
paragon571 paragon571 is offline
AKA: Linnea
FTC #0130 (blazing spirits)
paragon571 is an unknown quantity at this point
how do you do that with nxt-g edu
Mentor on FTC team 130. excited for new season.
Unread 13-03-2009, 22:36
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
On a program, click the NXT brick icon (top left button) on the bottom right control palette. Choose the memory tab and on the right hand sidebar you can rename the NXT beside Name
[FTC]: RobotC and NXT-G (The two programming languages) craig_yates FIRST Tech Challenge 1 30-01-2009 21:47
[FTC]: Help requested, the NXT is not showing the battery as being connected. crazilyrandom1 FIRST Tech Challenge 2 17-01-2009 11:24
Help! Can't send files to NXT Brick via bluetooth Raptorace22 National Instruments LabVIEW and Data Acquisition 0 24-11-2008 16:39
Frozen NXT Brick. devinejohnny General Forum 2 05-11-2008 21:34
Changing the Name... Joe Johnson Championship Event 1 10-10-2001 09:29
