| Thread Tools |
Rating:
Display Modes |
So I understand that we need to change the name on our NXT brick to our team number. How do I do this? Right now, it is set at the default, "NXT". Thanks!
(a QUICK response would be appreciated, competition is kinda tmmrw, hehe, procrastination FTW.) |
Re: [FTC]: Changing the name on the NXT brick
If you're using RobotC, simply go to "Link Setup" connect your brick via USB, then click "Rename NXT". After this, type in your team number, and you are good to go.
...I'm using LabView. Thanks though.
If you are using LabView:
Go to Tools menu then nxt module then nxt terminal click on find nxt in the name block type new name click on rename |
how do you do that with nxt-g edu
On a program, click the NXT brick icon (top left button) on the bottom right control palette. Choose the memory tab and on the right hand sidebar you can rename the NXT beside Name
| [FTC]: RobotC and NXT-G (The two programming languages) | craig_yates | FIRST Tech Challenge | 1 | 30-01-2009 21:47 |
| [FTC]: Help requested, the NXT is not showing the battery as being connected. | crazilyrandom1 | FIRST Tech Challenge | 2 | 17-01-2009 11:24 |
| Help! Can't send files to NXT Brick via bluetooth | Raptorace22 | National Instruments LabVIEW and Data Acquisition | 0 | 24-11-2008 16:39 |
| Frozen NXT Brick. | devinejohnny | General Forum | 2 | 05-11-2008 21:34 |
| Changing the Name... | Joe Johnson | Championship Event | 1 | 10-10-2001 09:29 |
