Go to Post I challenge the status quo - it's just me. - techhelpbb [more]
Unread 28-02-2009, 06:19
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Digital Side Car Error
Hi.
Before assuming that you have a bad sidecar, we ran into a problem yesterday at the DC regional of the DB37 cable vibrating out of the DSC (or maybe it was that collision in auton).
This causes what looks like a progressive failue, that started with the encoders and worked it's way to PWM's.
This cable is not anchored at the DSC end, but it can be.
Take a cRIO plug-in module that you are not using (Spare analog or digital) and remove the small hex posts that the db37 screws into.
Fit these posts to the DSC, (at each end of the db37 connector) and then re-install the cable.
This makes for a solid connection.
Phil.
Phil Malone
http://www.GEARSinc.org
Does the trailer have to be able to move side to side? eNyoron General Forum 1 04-01-2009 21:57
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
