Go to Post "The lowly snowflake is very fragile, but look at what they can do when they stick together" - Wayne Doenges [more]
View Poll Results: Was this useful?
Yes, it was! It helped point out diamonds in the rough 109 70.32%
No, its numbers generally did not correspond to robot's actual on-field performance 46 29.68%
Voters: 155. You may not vote on this poll
Thread Tools Rating: Thread Rating: 32 votes, 4.88 average. Display Modes
Unread 28-02-2009, 06:38
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Easy to use Offensive Power Rankings (OPR) program for mid-regional scouting
Originally Posted by Zholl View Post
This is pretty cool. I'm debating whether or not to use this or the matrix system I spent the last couple weeks setting up. I guess depending on the delay, doing it by hand is probably faster though, even if it is a pain. Anyway, seems to work fine on my vista system, and I didn't have to compile it with the SDK or anything. One question, though. Is it supposed to close after you enter a command after it gives you the requested stats?
I wanted it to pause at the end if the user double-clicked on it. I couldn't remember the "press any key to continue" API call, so I did it in the poor man's way:
if(!fRunWithoutCommandLineParameters)
int a;
cin>>a;
Offensive Power Ranking Calculations Greg Marra General Forum 4 18-03-2009 22:03
Offensive Power Rankings for 2008 Bongle General Forum 166 18-05-2008 15:05
Offensive+Defensive Power Rankings BornaE General Forum 4 05-04-2008 01:33
2006 Offensive Power Ratings sw293 General Forum 16 10-05-2006 17:04
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
