Re: I can't build or deploy! Error 6?
I believe the 0.0.0.0 needs to be set in the properties dialog for the cRIO. Right click on the cRIO item in the project window and put the correct IP in. This normally gets filled in by the new project wizard, but this is how to change it later. It is also possible that this is the name of the cRIO in the project and in that case, you change it in the same place.
Greg McKaskle |
What version does it show when you got to help -> About FIRST Robotics Competition Software?
| Run works but build&deploy doesn't | program1 | NI LabVIEW | 3 | 03-02-2009 22:32 |
| LabVIEW Woes: Build/Deploy time too long?! | leftylink | NI LabVIEW | 7 | 27-01-2009 21:52 |
| Can't Deploy All of Project to cRIO | MachineSMMC | NI LabVIEW | 2 | 15-01-2009 18:41 |
| Build Error S.O.S. | TimeOut | Programming | 2 | 10-02-2006 00:10 |
| Build Error | Chris.Steimel | Programming | 13 | 26-01-2005 17:44 |
