Go to Post "Why even bother building a robot if we're not gonna win?". The answer? To learn and grow. - MrBydlon [more]
Unread 16-02-2009, 13:34
PWHSrobotics PWHSrobotics is offline
PWHSrobotics is an unknown quantity at this point
Filters
Plugged in the gyros and accelerometers and they are jumpy. A while back one of our mentors said we were going to have to use filters on these readings, and I see through LabView there are build in filter vi's.
Are any other teams using filters for their Gyro's and Accelerometers, and if so which ones are you using?
Unread 17-02-2009, 18:34
Re: Filters
anyone?
Unread 28-02-2009, 11:58
brianc217's Avatar
brianc217 brianc217 is offline
None #1153
brianc217 is an unknown quantity at this point
Re: Filters
i would use them but i didn't even know labview had them. where are they?
Unread 28-02-2009, 15:45
Ridley444's Avatar
Ridley444 Ridley444 is offline
Programmer, Electrical Engineer
FRC #2859 (Blasterbots)
Ridley444 is an unknown quantity at this point
Re: Filters
If you are using LabVIEW then there is a very simple solution for filters. You can use a while loop and some shift registers along with the compound arithmetic vi for a quick and dirty fix for filters. Just make sure that the shift registers are initialized to zero.
Otherwise you can use arrays and replace with array subset Vi's for a more snazzy way of averaging.
Unread 28-02-2009, 15:48
Re: Filters
Or you can use the included filters. Be sure to use the Pt by Pt ones - the "normal" ones are meant to take a chunk of time at once, the Pt by Pt are meant to be used as things happen.
I encouraged my students to use a few lowpass filters, but I don't think they bit.
Kalman Filters nickmagus Programming 15 05-09-2008 23:20
Digital Filters? archiver 2000 2 23-06-2002 22:55
