Re: Lost Trailers
at mwr this happened a few times where they didnt get disabled. i dont know why the refs didnt immediatley disable them but at the end of the match the trailers were spilling balls out the top. not a good thing for the alliance that it happens to.
Re: Lost Trailers
If the trailer falls off the robot, that should be a field fault, and the match should be replayed.
I really don't understand why the poor team that has this happen to them would get disabled. Then the alliance is penalized twice for the field breaking? |
Re: Lost Trailers
If the team connects the trailer to their robot (which generally is the case), it's not the fields' fault (if it wasn't properly secured). If the force of a collision happens to cause a properly installed pin to come dislodged, that's just bad luck. Independent of how the trailer is lost, <G35> requires the robot to be disabled.
Re: Lost Trailers
I grew up on a farm, and we never "trusted" these types of pins having them "jump" out on occasion. I never lost a hitch pin though that had a secondary cotter pin properly installed. Small bumps while undertension can put a surprizing amount of vertical force into a hitch-pin. |
Re: Lost Trailers
If a team installs the pin with the clip over the end of the pin, and it manages to come out, how is that their fault?
Are volunteers/refs/the FTA checking the pin prior to the match starting? Maybe they should be, and that would eliminate the problem. If they were to check, and ok it and the trailer subsequently fell off, then it's a field problem, not a team problem |
Re: Lost Trailers
Yes at GSR they checked every robot at least once...
#7
Re: Lost Trailers
This doesn't sound like something that should be happening at all, and I was surprised to hear that it's such a common problem. Does anyone have a picture of the pinning system used in competition?
#8
Re: Lost Trailers
Re: Lost Trailers
oh...so their not ball hitch pins like this http://www.jamestowndistributors.com...SDG-193410.jpg
#10
Re: Lost Trailers
Re: Lost Trailers
It may be worthwhile to bring a couple packs of these;
http://www.mcmaster.com/#92401a643/=tg77b The actual hitch pins like this have a built in handle and a chain to keep the keeper attached. We had pins with keepers like what we are supposed to use this year, and they would often become unsprung and then bounce out. Anecdote. I was once hauling a manuer spreader back to our farm with one of these pins. I hit a bump, it can loose and the trailer passed me going down the hill. Not good. |
#12
Re: Lost Trailers
On a side note:Ive had(painful ) experience with the cotter pins in these breaking on my sailboat,I had two of these holding my sail-traveler-car onto the mail-sail blocks, the pin snapped and the blocks flew up, and the boom came accross and hit me square in the face and broke the piece where the boom connects to the mast($80) there plenty strong for the trailers though.... |
#13
Re: Lost Trailers
Team 811 took some pretty huge hits at GSR and our pin never came out... They seemed like a very secure hold to me...
#14
Re: Lost Trailers
Our 'bot lost its trailer after a hard hit from another. Worse, an alliance mate drove away from the trailer as soon as autonomous started. The killer: this was in the same match.
The other team probably had the pin miss the trailer tongue completely, the only scenario that seems likely. Our pin was installed by a pretty sharp young man, our programmer. It was also the first time he had done it (all the kids were having a try at different responsibilities, as we were so far down in the rankings). Here's what's weird: he said the pin was still in the hitch through both upper and lower holes. He said he had put the clip around the pin. I didn't see it myself, so can't verify or deny. It seems unlikely, but at the same time, I don't see how the trailer could have made it partially through the match if it hadn't been connected to begin with. I don't know if a team can supply their own pin to be sure it's good. Pin installations weren't being checked by staff, as far as I can tell. (Two trailers off in the same match? No double-checking there.) But, I would strongly recommend you do what you can to prevent separation. This is a terrible way to kill a match. The trailer sits there like a dead duck, getting dumped on. This kind of thing should simply not happen. mt |
#15
Re: Lost Trailers
We lost our trailer twice (once in practice, once during an actual match). Both times we had the pin secured correctly, as both myself and the operator checked it. We made the field crew aware that we had lost it twice (we were the only team to have such a problem), and they checked it for every match afterwards. We brought a pair of pliers to apply a little extra pressure up. Looking at our trailer hitch, it appears that the spring clip was getting pinched between the trailer hitch and the trailer tongue. The spring steel clip had worked it's way into our trailer hitch at least 1/8". And yes, we did pass inspection, and the trailer's bumper contacted our bumper long before the trailer tongue touched the bumper. As far as we could tell, the high speed collisions were compressing our bumpers significantly which in turn pinched the pin. We cut off our back corners, but our robot was still as wide as longbots who had no trailer troubles. Perhaps it has something to do with open center pool noodles vs. solid pool noodles?
| No-show teams and trailers | StevenB | Rules/Strategy | 82 | 22-02-2009 21:02 |
| Height of Vision Target on Trailers | Tom Line | Technical Discussion | 1 | 03-02-2009 11:14 |
| Weight of Trailers | vivek16 | General Forum | 23 | 17-01-2009 17:02 |
| Removing game pieces from Trailers | PhilBot | Rules/Strategy | 51 | 06-01-2009 17:19 |
| Is pinning opposing robots trailers allowed? | spiffyspleen | Rules/Strategy | 22 | 05-01-2009 16:47 |
