Go to Post Frankly, I love CD and everything it stands for. I've made more friends from this forum alone than I ever expected to meet in FIRST. I'd give just about anything to keep this system up, upgraded and going on long into the future. It's not even enough to show my thanks and gratitude. - BandChick [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 27-02-2009, 10:51
Larry Lewis's Avatar
Larry Lewis Larry Lewis is offline
The Spiky Hair Guy
FRC #1511 (Rolling Thunder)
Larry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to all
2009 Team 1511 LabVIEW Scouting Database
Here is version 1.0 of the 2009 Scouting Database.
2009 Team 1511 Scouting Database
This database is intended to be used by any FIRST teams interested in recording match data on teams during practice, qualifying, and elimination rounds. The database is relatively simple consisting of a configuration menu, submission menu, retrieval menu, and new this year a Pit Scouting Menu. Examples of these menus are attached in the picture files.
There is also a robot picture program so you can take the pictures of teams robots and easily bring them up in the retrieval menu.
The database can be networked to multiple computers to allow the scouting of 6 teams simultaneously during the match. As long as all computers look in the same directory location to store files. This can be setup in the config menu.
This year I have removed the dependency on MS Excel. Scouting data is written into text files that can be opened with Excel, Wordpad, or Notebook if desired.
Another feature is automatic team list generation based on what event you are at. The automatic mode on the submit menu is not complete but should be for the next revision.
Both the installer for the application and the source code are included in the zip file. Feel free to look through the source code written in LabVIEW 8.5.1 and modify for your own usage.
I will be making new updates such as pulling Twitter match info and a statistics summary spreadsheet maker.
If you have any feedback or questions please let me know.
ID:	7569  Click image for larger version
ID:	7570  Click image for larger version
ID:	7571  Click image for larger version
ID:	7572  Click image for larger version
Unread 27-02-2009, 12:02
OScubed's Avatar
OScubed OScubed is offline
Lee Drake, CEO, OS-Cubed Inc.
AKA: Lee Drake
Team Role: Parent
OScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond repute
Send a message via ICQ to OScubed Send a message via AIM to OScubed Send a message via MSN to OScubed
Re: 2009 Team 1511 LabVIEW Scouting Database
And here I thought this had to do with the Scouts update in Team Fortress Seriously Larry - great job on this. I know how hard you and the programming team worked to get this out the door. It was fun working on twitter feed with you. Hopefully the next version of labview will have better RSS support.
Lee Drake, CEO, OS-Cubed, Inc.
Business Mentor - team 1511
Rochester, NY
Building optimal, stable, secure solutions to your business challenges.
Unread 27-02-2009, 12:15
The Spiky Hair Guy
Thanks Lee! The next version will be able to pull the twitter info but not through the RSS. It will be based on HTML reads and parsing the data that way. I will also be looking to read match results.
Unread 27-02-2009, 14:34
Sogtwinster's Avatar
Sogtwinster Sogtwinster is offline
AKA: Andrew Ebert
FRC #3023 (Stark Industries)
Sogtwinster is an unknown quantity at this point
Send a message via AIM to Sogtwinster Send a message via MSN to Sogtwinster
Exclamation Re: 2009 Team 1511 LabVIEW Scouting Database
I am having a problem with the config page. It keeps saying:
"Error 7 occurred at Open File+.vi:Open File"
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
Any reason why. I just ran the installer and left the default place.
Andrew Ebert
Unread 27-02-2009, 15:40
The Spiky Hair Guy
Possible reason(s):
Andrew Ebert
Andrew, sorry for the error. I will investigate. I did have a issue with relative paths in the application but I thought it was fixed. There is a chance I may have not switched back the boolean that controls this. I will post a fix as soon as possible. Thanks for the feedback.
In the meantime try to create a folder in the root directory called TeamData. Do this if the directory already doesn't exist. Also could you provide me with the default path that came up on your computer?
Thanks!
Unread 27-02-2009, 16:52
The Spiky Hair Guy
Possible reason(s):
Andrew Ebert
Andrew, I have a temporary fix until I can make the corrections to the installer build.
First uninstall the program under add/remove programs in control panel.
Then reinstall the program but change the install path to:
C:\Program Files\Team 1511 Scouting Database\V1.0\
Once that is complete navigate to that location and delete everything in the directory.
Then Download this zip file here
Next unzip the contents and place them in your Program Files Directory.
The new unzipped files should have the following executable path and folders.
C:\Program Files\Team 1511 Scouting Database\V1.0\Team 1511 - 2009 Scouting Database.exe
C:\Program Files\Team 1511 Scouting Database\V1.0\data
C:\Program Files\Team 1511 Scouting Database\V1.0\PitData
C:\Program Files\Team 1511 Scouting Database\V1.0\Robot Pictures
C:\Program Files\Team 1511 Scouting Database\V1.0\TeamData
C:\Program Files\Team 1511 Scouting Database\V1.0\TeamLists
Sorry for the mistake when I get a chance I will fix the installer file so that it puts everything in the right directory structure.
Thanks!
Unread 27-02-2009, 23:45
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Larry,
This is really sweet. Which parts of the RSS are you having problems with?
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 28-02-2009, 10:57
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Just curious what "ninja" maneuverability is.....and what the other choices are!
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 01-03-2009, 15:41
The Spiky Hair Guy
Originally Posted by Danny Diaz View Post
Larry,
-Danny
Danny,
If I tried to put the address for the RSS feed into the Datasocket Read it would pop up a error. It seamed to open the link ok but as soon as I tried to do a read it would error. I wonder if my data type is incorrect. I was just using a string value but maybe it needs to be something else. Any ideas?
Thanks,
Larry
Unread 01-03-2009, 15:46
The Spiky Hair Guy
Well I figured that a ninja is quite maneuverable. Based on all the ninja turtle movies I have watched multiple times.
Other values are more generic.
Poor
Fair
Good
Great
Unread 01-03-2009, 15:50
The Spiky Hair Guy
New Version 1.1!
Here is a new version of the database.
Team_1511_2009_Scouting_Database_V1.1_Installer-Source.zip
This version fixes the installer issues that were in the previous version. It should allow users to install wherever they want but to be honest the default should work best.
Please provide feedback if anything needs improvements.
Thanks!
Unread 01-03-2009, 17:03
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
Great job.
Just wondering how do you check the pit scouting information?
Unread 01-03-2009, 22:01
The Spiky Hair Guy
Originally Posted by professorX View Post
Great job.
Just open the file with one of three programs. Excel, Wordpad, or Notepad. It is just a tab delimited text file. I think for the next version I will just save it as a .txt file.
The pit scouting file is located in the base directory of the application under the PitData folder. For example:
C:\Program Files\Team 1511 2009 Scouting Database\V1.1\PitData
Last edited by Larry Lewis : 01-03-2009 at 22:03. Reason: Forgot to put something in post
Unread 02-03-2009, 08:58
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
i got 404'd trying to open it.
Is now an engineer thanks to FIRST.
Unread 02-03-2009, 09:08
The Spiky Hair Guy
Interesting. I just tested the link and it seemed to work fine. Could you give me any more details on what error you saw?
[IMG] code is Off
paper: New Scouting Database from Team 2834 Ed Law Extra Discussion 232 08-03-2016 10:54
2008 Team 1511 Scouting Database Larry Lewis Scouting 22 19-03-2008 19:21
Team 166 Scouting Database Dan Petrovic Scouting 2 12-03-2008 21:10
1511 LabVIEW Scouting Database Release Larry Lewis Scouting 7 02-08-2007 15:18
Team 48's Scouting Database Shelley_delphi chick Scouting 11 28-05-2002 02:14
