Go to Post From a coaching standpoint, I can tell you...the coach is NOTHING without valuable scout information. If the coach is nothing, the robot is NOTHING. It all starts from the scouts...get your kids to see this. - Brandon Holley [more]
Unread 01-03-2009, 18:58
Re: Help with Personal labview project
I've attached an image of a slightly modified VI. I cleaned up the wires, got rid of the timeout setting that was redundant, and put a loop around the serial read. Does the loop make sense? If you only run the node once, you can only read one byte.
Greg McKaskle
Help with connecting default dashboard project mminutto NI LabVIEW 2 30-01-2009 15:26
Forklift project with mecanum wheels HELP adra Technical Discussion 12 21-01-2009 00:44
Fun Personal Project Caio Chit-Chat 14 23-03-2008 22:03
Urgent help with a project; brennerator Technical Discussion 3 05-03-2007 13:40
help with simple project erikh98 Technical Discussion 8 27-08-2004 11:24
