Go to Post Too bad MI isn't allowed to participate in FTC - Cory [more]
Unread 01-03-2009, 15:00
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Field Static Solutions
Hello All,
It was speculated that static build up and discharge from machines to the corner player stations (Airlocks?) could have cuased some field system issues at regional events this weekend.
The purpose of this thread is for people to discuss suggestions to prevent this in the future. lets share some of our ideas here.
I suggest that FIRST modify the trailer design to include a ground wire that drags on the floor under the trailer. The wire could be fixed to the trailer tounge where it extends into the trailer body. The wire would be under the trailer and not visible.
This would also create a uniform solution rather than asking teams to take chassis grounding into their own hands.
Any other thoughts?
Thanks, and good luck!
Unread 01-03-2009, 15:20
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: Field Static Solutions
well, and what about driver stations?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 01-03-2009, 15:47
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
There was an information sheet released awhile ago detailing how you should do this. it involved attaching a pwm cable to the bottom row of pins on the IO ports and attaching the other stripped ends to the closest screw.
as for the robot, we just bolted a piece of wire to the bottom of our robot. very easy fix, only took a few minutes.
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Unread 01-03-2009, 15:48
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Did any team with a non-metallic robot (wood, fiberglass, plastic, carbon fiber, etc) have problems with static?
Unread 01-03-2009, 15:53
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
I don't think the driver's station grounding wire is enough. It grounds the circuit to the case, but the case isn't grounded to anything. I think there should be a ground strap that clips onto the driver's station that's connected to an earth ground. Similair to an anti-static mat used when working on electronics.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 01-03-2009, 16:29
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
I didn't have, nor hear about, any static problems at DC. Has anyone actually had problems with buildup, or are we discussing how to prepare against the pickle rebellion?
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 01-03-2009, 16:34
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
My team (964) bricked our station at the Buckeye regional, and there were a ton of other teams having issues with their system. The fix with the grounding to the casing worked, though.
Somewhat related, the Buckeye field controller used a cheap USB soundcard for the game sounds, and it was shorting out our system all-day Thursday. So lot's of static/ESD issues here.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 01-03-2009, 16:56
AKA: Richard Raitt
FRC #1793 (Pilots)
Okay, thanks for clearing that up.
Unread 01-03-2009, 17:48
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Well if you are Dean Kamen your "spritz" the field with water. At the NH regional the field operators were pouring bottles of water on field near the airlocks and Dean Kamen went around with a bottle of water spraying the airlock.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 01-03-2009, 18:15
Squirrel -
I believe the issue is on the driver side, not the robot side. Robot A releases its energy to the field, but may impact any of the six.
For whatever reason, the FRP+rover wheel combination has some serious vandegraph potential.
Unread 01-03-2009, 18:32
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
A though was brought up by some of our team...
Ground the DS box to the field table so that we don't have the issue...
There were times when our robot hid the airlock and killed the system hehe...
But i agree with rob a grounding strap on the trailer would be ideal....
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 01-03-2009, 18:56
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Increase humidity to 60%. The water vapor in the air helps make static electricity harder to build up.
Unread 01-03-2009, 19:00
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
For a drag chain or grounding strap to discharge a static charge on a robot it would need to contact a conductive surface. Regolith is nonconductive. Please tell me how this will help.
___________________
- Tennyson, Ulysses
Unread 01-03-2009, 19:25
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
We had both alliance control stations die because someone would ram the stations and the grounding wire preventing the damage of the controls came loose. We went down for like an hour twice because of this. Also on thursday we had an average down time of 10 min. they fixed it for friday and it worked really nicely. Some of our mentors have mentioned that they do have grounders for people to keep you from killing your electronics after your robot builds us so much static electricity. We also had a lot of teams loose the control boxes for no reason. The NI guy who did a TON of work for the design and programing of the control system was really frustrated. Luck-fully for week 2 competitors most glitches have been worked out for you.
Unread 01-03-2009, 19:29
viking's Avatar
viking viking is offline
Viking Robotics
AKA: Robert Dudek
FRC #1777 (Viking Robotics)
viking will become famous soon enoughviking will become famous soon enough
Kansas City had static problems, along with grounding issues on the main driver station junction box. The FTA stated that after several high speed collisions with the drivers station by robots the junction box grounding was comprimised.
Viking Robotics Team #1777
2006 FRC Colorado Regional Rookie Inspiration
2007 FRC Greater KC Regional Daimler Chrysler Spirit
2007 FVC St Louis Connect Award
2009 FRC Greater KC Best Website Award
Communications -- Solutions/Ideas Ken Patton District Events 8 28-08-2008 09:46
Awards -- Solutions/Ideas Ken Patton District Events 2 23-08-2008 21:38
Inspections -- Solutions/Ideas Ken Patton District Events 13 18-08-2008 21:01
Volunteers -- Solutions/Ideas Ken Patton District Events 15 07-08-2008 20:39
Flag Solutions... Chaos204 General Forum 38 09-04-2007 16:21
