Go to Post Finally, they're getting rid of the spotlights. I'm sick of seeing ridiculous inside jokes up there. - Karthik [more]
Unread 01-03-2009, 19:50
psychomonkey psychomonkey is offline
Mr. February
AKA: Seth Rhodes
FRC #1592 (Bionic Tigers)
psychomonkey is an unknown quantity at this point
Question Autonomous selection from dashboard
Hello everybody,
I would like to be able to have an enumerated constant on the dashboard to switch between the different autonomous codes that I have. I am using a case structure to flip between codes. I can hook an enumerated constant directly to the case structure, but I would like to make it a global variable so as to reference it from the dashboard. Is it even possible to reference autonomous independent vi to the dashboard in the basic framework?
In a time... When the greatest comeback occured... There was... MR. FEBRUARY!!!
Unread 01-03-2009, 20:07
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Re: Autonomous selection from dashboard
Through the basics I learned through our programers, the only effect the control box has on autonomous is the disable. We just use switches on the robot because they work and there's a lot less hassle for the robot to identify the code you want it to use and it is faster to install on the robot and the code writing seems to be easier. If you really want to try keep people updated because our team had a mentor that tried to but couldn't figure it out and just reverted back to the switches on the robot.
Unread 01-03-2009, 20:18
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
I may be wrong, but I thought that you couldn't use a computer for input during competition? Wouldn't a control on the dashboard be useless if you can't use it? Am I missing something?
Why not use a switch wired to the DIO pins of the DS? That's what I plan on doing for autonomous mode selection. I would rather have switches on the control board than on the robot. That way I can check right before the match and be absolutely sure, plus I plan on putting a bunch of other stuff with it, LEDS and the like. Maybe a 7seg if I get really bored between now an Mar 26.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 01-03-2009, 21:34
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
While 1675 was messing around with more autonomous routines at Midwest this weekend, we found out that (at least the way we were doing it) when you try to read the digital IO pins in autonomous, it takes them from the state they were at driver station boot.
If you go this route, make sure you thoroughly test your system and that drivers know of any special procedures they need to follow to choose the mode they want.
(We ended up not putting it in yet because we only used one autonomous routine.)
Unread 01-03-2009, 21:49
Mr. February
AKA: Seth Rhodes
Well, if input isn't allowed, that does make it slightly easier. Now I just need to find out how to wire a boolean to an actual switch or potentiometer on the DIO of the DS. btw, I am not only the programmer this year, but I am also the electrician and driver. Keeping myself up to date should be easy.
Unread 01-03-2009, 22:00
O-H
FRC #0048 (Delphi E.L.I.T.E.)
We implemented a similar select auto program from OI method as we've used in past years, except we didn't use the Driver Station's digital IO - instead, we used the left and right stick push buttons on our Logitech gamepad to select start position and program number, respectively:
(This is obviously Wind River code. The code resides in the "Disabled Periodic" routine.)
/* * Determine the autonomous start position and program number. 1 = NEAR, 2 = CENTER, 3 = FAR Use left stick push for start pos cycle; right stick push for program cycle. */
#define MAXPOS 3
#define MAXPROG 8
//starting position if (not autopos_sw) autostartlock = 0; if ( (autopos_sw) && (autostartlock == 0) ) { if (autostartpos < MAXPOS) { autostartpos++; } else { autostartpos = 1; }
autostartlock = 1; }
//autonomous program number if (not autoprog_sw) autoproglock = 0;
if ( (autoprog_sw) && (autoproglock == 0) ) {
if (autoprognum < MAXPROG) { autoprognum++; } else { autoprognum = 1; }
autoproglock = 1;
//Update the LCD Display
Write2LCD();
Write2LCD contains code which updates the nifty new user-writeable DS LCD display screen with robot info, including text descriptions of each auto program we run. Who needs a PC dashboard, anyway?
Unread 01-03-2009, 22:14
Mr. February
AKA: Seth Rhodes
Now THAT is really cool! If I could assign a button on the left most joystick to toggle between autonomous codes, that would be !@#$ hot! How would you go about using the LCD of the DS in LabView?
Unread 01-03-2009, 22:19
O-H
http://thinktank.wpi.edu/article/144
Unread 01-03-2009, 22:23
Mr. February
AKA: Seth Rhodes
Wow, that is really useful! Thank you so much!
Unread 01-03-2009, 23:45
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
The protocol for the dashboard allows only communication from the cRIO to the DS.
Unread 02-03-2009, 06:59
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
We attached to switches to the digital input on the DS. These are read in disabled mode and set a global variable in Labview. We use 2 switches to select driver mode (2 switches, 4 choices, switched between Arcade, Tank, Tank Drive on a Gamepad and two stick arcade). We have three switches for auto mode selection which gives us 8 possible auto modes. The selected switches are displayed on the driver station, driver selection is on the front page, and auto mode is on the second page of display.
Switching to/from autonomous mode RDD Programming 6 12-02-2007 16:14
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
Setting Autonomous Settings from OI Tom Saxton Control System 4 14-03-2005 22:33
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
