Go to Post Seriously, when I grow up (or if I grow up) I want to be just like Al. - Paul Copioli [more]
Unread 01-03-2009, 22:46
Cuse's Avatar
Cuse Cuse is offline
AKA: Matt Mancuso
FRC #0175 (Buzz Robotics)
Cuse is an unknown quantity at this point
Re: DS Question with the GET ALLIANCE function
Nevermind.
Last edited by Cuse : 02-03-2009 at 11:53. Reason: Apparently the "Position" function doesn't actually use position data. Go figure.
Unread 02-03-2009, 08:07
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Post Re: DS Question with the GET ALLIANCE function
We were going to use the "Position" property to select different autonomous routines depending upon the value. At the DC regional we were told by the people running the FMS that there was no correlation between the "Position" value and actual starting position on the field. Since alliances determine starting position among themselves prior to each match, this data would have to have been entered manually prior to each match.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 02-03-2009, 14:05
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
We will use it to determine which trailer to track with the camera.
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 02-03-2009, 16:01
gwytheyrn gwytheyrn is offline
AKA: David
FRC #0461 (West Side Boiler Invasion)
gwytheyrn is infamous around these parts
Send a message via AIM to gwytheyrn
Is there any way to simulate the field control (setting alliance) so I could test without switching my code back to a switch? I currently have code defaulting to red unless the get alliance returns blue (anything else will set to red).
Unread 02-03-2009, 17:19
You want the FMS Light software. Links are at http://www.usfirst.org/community/frc....aspx?id=10934 near the bottom of the page.
Unread 02-03-2009, 17:31
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
This is exactly what I was going to suggest, except, I have not verified if this will work on the same PC you are programming with.
Alan, or anyone else for that matter,
Do you have experience testing this function with FMS Light? If so, can you give us a quick rundown of the procedure you used? I'm certain we could figure it out on Practice day, but if we had a verified procedure to follow, it could save us a lot of trial and error.
Unread 02-03-2009, 21:20
fritzdejongh fritzdejongh is offline
Coach
FRC #2704
fritzdejongh has a spectacular aura aboutfritzdejongh has a spectacular aura aboutfritzdejongh has a spectacular aura about
get alliance worked for my team at midwest regional, for choosing which flag orientation to go after. We displayed the alliance setting in our dashboard so we could verify it was set correctly. Out of paranoia, our programmers allocated joystick buttons to override in case the field system didn't work, but they didn't need them.
Unread 03-03-2009, 16:10
Norton Norton is offline
Computer Engineering
FRC #0383 (The Brazilian Machine)
Norton is an unknown quantity at this point
Send a message via MSN to Norton
I would like to know what does the function GET ALLIANCE returns in the alliance output, anyone knows a number, a bolean a string ???
if my team is RED it returns 1? or 0? or RED?
thanks
Unread 03-03-2009, 16:24
billbo911's Avatar
thanks
It returns an "enum" of either "Red" or "Blue".
To see this your self, put the vi into your project. Connect the output you want to a case structure. Hit "Ctrl+H" to bring up the Context Help, then put your cursor over the output of interest.
Get Alliance VI Heath Programming 2 14-02-2009 22:00
can't get control system to function pagemauck Programming 9 10-02-2009 12:26
Get Alliance VI rpcoe NI LabVIEW 2 09-02-2009 22:12
Get Alliance VI help! Xenosthebest Programming 2 03-02-2009 19:32
Get Angle Function in Labview popo308 Programming 2 01-02-2009 15:16
