Go to Post College was the best twenty years of my life. - Richard Wallace [more]
Unread 03-02-2009, 12:57 AM
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: Watchdog!?!?!?!
Did your drive shut down before or after it moved in autonomous? Did the failures occur in your first two matches or was it intermittent? Did the autonomous work in testing before you hooked up to the field system? Did you get the "watchdog" message?
It doesn't make sense to me that code would generate intermittent hang ups. Our system worked fine before the failure, and then again after rebooting. That implies something outside the code is influencing the system.
WatchDog Timeout popo308 Programming 3 02-22-2009 10:04 PM
Watchdog darty NI LabVIEW 8 02-16-2009 09:11 AM
System: Watchdog problems dboisvert C/C++ 7 02-16-2009 02:36 AM
System: Watchdog problems dboisvert C/C++ 1 02-15-2009 08:12 PM
Watchdog Barchechath Programming 6 02-10-2007 08:05 PM
