Go to Post "A robot can always be fixed but a match can never be replayed." - Brian C [more]
Unread 02-03-2009, 00:46
phoenix phoenix is offline
phoenix is an unknown quantity at this point
Exclamation Automous code
can sume one give to our team a Automous code pls
i asking from all teams pls help to our team
Unread 02-03-2009, 01:00
Electrical Engineer
Rookie Year: 1995
Re: Automous code
I am going to strongly suggest that you watch Tip Jar Video # 8.
Actually, I suggest that you start with number 5 and watch them in sequence.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 02-03-2009, 04:29
Re: Automous code
what we tride to do dont work thas way we ask
Unread 02-03-2009, 05:01
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: Automous code
See this thread:
http://www.chiefdelphi.com/forums/sh...ght=autonomous
It has both Labview and C++ code for general use.
Unread 02-03-2009, 06:46
Electrical Engineer
Rookie Year: 1995
Re: Automous code
Please post what you tried and someone will look at it and comment.
Mike Betts
Unread 10-03-2009, 12:44
Garii's Avatar
Garii Garii is offline
Registered Abuser
AKA: Jared Hankle
FRC #3044 (BE4)
Garii is an unknown quantity at this point
Send a message via AIM to Garii
Re: Automous code
This is a problem NI is having with alot of teams [at least where I was at FRL]
the problem I dont think is your code but rather, that you need to Build your code first after every change. However if I misunderstood your problem or if I'm incorrect, then simply write a random drive will work. Tell your robot to move forward with a SetTime vi and a while loop and report your results here.
-The Garii- aka Jared Hankle
Ballston Spa Labview Programmer
new team slogan-"Can I Get Some Linux With These Fries?"
Automous Programming professorX NI LabVIEW 9 02-03-2009 09:07
Team 1675' s AutoFlex automous Program bcieslak Programming 8 14-03-2007 20:29
Automous Code? Raikon Programming 5 29-01-2007 01:13
so lost we need help with automous evilhunter Programming 2 21-02-2005 13:54
2001 2002 in Automous SpaceOsc Control System 12 17-05-2004 01:52
