Go to Post Big scoop for everyone here: All divisions are stacked with talented teams. It's like this is a really big event or something. - PayneTrain [more]
Unread 02-03-2009, 07:56
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
paper: Robot Weight Watchers
Thread created automatically to discuss a document in CD-Media.
Robot Weight Watchers by IKE
Unread 02-03-2009, 08:00
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Re: paper: Robot Weight Watchers
This paper was requested to help other teams find good ways to save weight after their robot has shipped. We are getting many more examples this year and I will hopefully remember to update it. 1 idea that we brainstormed and calculated at the last team meeting
PVC rollers are deceptively heavy. 2" sched 40 is 30 grams per inch length. 2" 035 wall aluminum is 10 grams per inch. Our shooter has 15" of tube length therefore we will be able to save 300 grams switching over to thin wall aluminum rollers. This is nearly 3/4 of a pound!
Please add other general tips into this thread as teams are now competing and may need teh advice.
Unread 02-03-2009, 08:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Nice paper, thanks!
I like the mention that 7/8" round tube will fit into 1" x 1/16" square tube....and also remember that 3/4" round tube will fit into 1" x 1/8" square tube, so you could cut the center out of a long, heavy square tube, put some smaller thin light round tube in, and rivet it together at the ends, should be plenty strong if there are no parts attached in the middle.
Black ABS sewer pipe is considerably lighter than PVC, and it won't shatter either.
Using sheet aluminum brackets, riveted to the ends of thinwall aluminum tubing, seems to work pretty well, and could save some weight compared to other construction methods, and doesn't require welding or milling.
Look at using plywood, it's surprisingly light and stiff, and it's also easy to cut with a jigsaw and a hole saw.
Unread 02-03-2009, 08:53
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Thank you for this, very informative, and we really could have used it last week (before 8 hour work window we were 70 pounds over )
Is now an engineer thanks to FIRST.
Unread 02-03-2009, 09:02
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Double Wow. You guys had such a beautiful machine last year. You sure that there isn't a tube filled with Anodizing solution? How did you guys make out?
Unread 02-03-2009, 15:11
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
save weight(alot) by using sign-board instead of lexan(cheaper and almost as strong)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 02-03-2009, 16:00
Onward through the fog.
Thank you for putting this together.
~ Helen Keller
(1880-1968)
Unread 08-02-2011, 12:57
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
OK folks, Week 5, time to throw your robot (or stack of robot parts) on the scale. If you have been careful and diligent all along, there should be no big surprises. If you have been randomly bolting stuff together, this could be a wake-up call, (now is better than ship day).
If you don't have a fully assembled bot, remember wire and bodywork can eat up weight quicker than you would expect. Make sure you have some extra pounds. If not, now is the time to start substituting heavy parts for lighter ones.
Unread 18-02-2013, 15:46
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
I am a little late with this reminder, but folks, please throw your robot on a scale before you bag it. If overwieght, please read through some helpful tips before you break out the drills. I would hate to see your season end before it starts due to filling a CRio full of shavings.
Robot Weight ScottieDo555 General Forum 31 30-01-2008 08:43
pic: 229 - Robot Weight Watchers JVN Extra Discussion 9 06-02-2005 11:05
Disney Movie Watchers? Brm789 Chit-Chat 1 01-03-2003 15:47
Robot weight dimroed Rules/Strategy 3 18-02-2002 21:31
