Go to Post Your team will be more of a team and not a group of students who are just building a robot. Instead of being in FIRST, you will be FIRST. - JackN [more]
Unread 02-03-2009, 10:08
Doctorwho's Avatar
Doctorwho Doctorwho is offline
FRC #0467
Doctorwho will become famous soon enoughDoctorwho will become famous soon enough
possible solution to the static problem
As seen in last weekend's regional competitions the electro-static discharge caused by the rover wheels and the floor can fry speed controllers, driver stations, and even knock the field systems out of whack.
It could be possible that anti-static spray could be used on your drive wheels and control board to prevent any catastrophic discharge. Plus the spray is pretty cheap and can be picked up at almost any office supply store for around $3-4, you can also buy industrial-strength spray from McMaster-Carr for $11.57 for a 11.5oz can (part # 6038T11)
Any thoughts?
Solution to camera problem techkid7 Programming 1 12-01-2009 08:42
Onan Generator Control Problem - RC as solution? RyanN Electrical 8 01-12-2008 16:45
pic: Banebots carrier plates problem & solution Elgin Clock Extra Discussion 14 10-03-2007 07:50
