Go to Post And yes. The Super Bowl is on, and I'm replying to a thread on Chief Delphi... - BobbyVanNess [more]
Unread 23-02-2009, 13:33
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Basic Robot Main vi
If we are not using cameras, do we delete the second and third while loops showing in the Basic Robot Main vi?
Is there a need for them? Will they hurt anything if we leave them there, but are not uing them?
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 23-02-2009, 14:12
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
Re: Basic Robot Main vi
As far as i know...it should not cause any issues. Just make sure you delete the camera open.vi as well as the camera close.vi and I think it should all work fine.
Unread 23-02-2009, 18:29
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
We used the timing loop, but deleted the whole camera loop. Seems to work fine and is faster when doing the "trace execution" on the PC, since it has one less loop to go through.
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Unread 23-02-2009, 21:17
FRC #1254 (Entropy)
What is the timing loop used for?
Unread 02-03-2009, 01:31
We put a 1 second delay inside the timing loop and increment a global counter in the timing loop. In the autonomous code we can read the global variable to see how many seconds have passed since autonomous started. We use this for timing movements during autonomous.
Adam Bryant
Programming Mentor
Team 1583
Unread 02-03-2009, 09:09
That certainly works, but if you would rather, you can put your time comparison directly in the auto. If you place a GetTime function at the beginning of your auto, and another inside your loop or other places in your code, you just subtract to get your elapsed time.
Greg McKaskle
Unread 02-03-2009, 11:25
gwytheyrn gwytheyrn is offline
AKA: David
FRC #0461 (West Side Boiler Invasion)
gwytheyrn is infamous around these parts
Send a message via AIM to gwytheyrn
You could use the structure posted
http://www.chiefdelphi.com/forums/sh...5&postcount=13. That make the loop run for 15 seconds and it will also monitor the amount of time elapsed in ms. This gives you a little more resolution and allows for a smaller step if you're trying to ramp based on time
Unread 03-03-2009, 15:54
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
This thread also posts multiple versions of autonomous,
http://www.chiefdelphi.com/forums/sh...590#post828590
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Using Robot Main LiLFiL Programming 1 14-02-2009 18:51
Coordinating Robot Main VI with Autonomous VI jjauss Programming 2 07-02-2009 09:26
Dashboard and Robot main with Axis camera Team2883 General Forum 9 10-01-2009 07:35
Basic Robot Layout gsorozco Technical Discussion 8 12-02-2006 19:15
Basic Robot Layout gsorozco Website Design/Showcase 0 30-01-2006 02:13
