Go to Post So in the words of one Leroy Jenkins, "Time's up, let's do this." - Frenchie461 [more]
Unread 01-03-2009, 21:21
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Turrets and cameras
Those who have actually played in a game and have a turret that is aimed by a camera, what has been your experience?
I am hearing in the forums that the lighting is bad and cameras are not being effective. Is this true?
Doug Leppard
Unread 01-03-2009, 21:29
gwytheyrn gwytheyrn is offline
AKA: David
FRC #0461 (West Side Boiler Invasion)
gwytheyrn is infamous around these parts
Send a message via AIM to gwytheyrn
Re: Turrets and cameras
Well, the code provided by FIRST detects the target fairly well in the pits at Buckeye. I'm not all sure how it was working on the actual field, with incandescent bulbs instead of fluorescent/LED lights, and I didn't calibrate it at all. My drive team tells me it worked fairly well at a distance, but is not very good close up (This is due to MY programming, since the turret won't turn fast enough to keep the target in the field of vision up close)
Unread 01-03-2009, 21:37
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
From what I hear the stadium lighting is totally messing up cameras, I've only heard that from a couple sources though. Just be warned that you are very likely going to have to re-configure your camera settings for the on field lighting conditions.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 01-03-2009, 21:46
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Are they allowing teams to go on the field during breaks (primarily lunch) to calibrate their camera with field conditions? I remember doing that at a number of regionals in 2006 and 2007, it was very helpful.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 01-03-2009, 21:52
chanj chanj is offline
AKA: Justin Chan
FRC #1732 (Hilltopper Robotics)
chanj is an unknown quantity at this point
Send a message via AIM to chanj
At the Midwest Regional, after the practice matches on Thursday during lunch we were allowed to go onto the field to check the camera software.
What we found out was that the lighting really messed with the area percent on the targets, so we eventually gave up on using it.
We found that turning down the brightness helps a bit.
Unread 01-03-2009, 21:57
AKA: David
perhaps this isn't a good idea, but instead of using area function provided, I suggest doing your own area calculation using the rectangle it finds. Oh, and how would one go about calibrating camera? Do you just run the white balance vi that came with the example and make sure that the set white balance function is nowhere in the normal main (as to not overwrite the calibration)?
What were you using for brightness (and white balance)?
Unread 01-03-2009, 22:13
AKA: Justin Chan
In the example (2 color tracking) there was a brightness selection, that had been defaultly set at 40, which we turned down to 0.
I don't think we had time to check out white balance (we programmers were getting really hungry by that time).
How exactly does the rectangle work?
When we were using area, we noticed that it pretty much cut off a side the target.
Unread 01-03-2009, 23:01
GearsOfFury's Avatar
GearsOfFury GearsOfFury is offline
Former guy that does stuff
AKA: Mark Anderson
GearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to behold
We took advantage of the calibration time during lunch on Thursday, and found that the images we were getting were basically just glowing orbs of (barely) green and pink. We couldn't find any brightness, WB, or exposure settings that made it work. We found setting brightness low (like 10... sounds like 0 would have worked too?) helped a bit but we could never find green. Camera worked GREAT in the pits and on the practice field.
We did find a target once or twice in autonomous with the 'flourescent 1' and 'auto' settings for wb/exposure but it was way too unreliable to be used during teleop.
I'd really appreciate hearing from anyone who got the camera to work under those super-bright lights on the field. I know FIRST tested the camera "under FRC competition conditions" but I wonder if they tested with the white FRP floor? I'm thinking it may be reflecting a whole lot more than the classic carpet we're used to... and they probably selected the camera long before Lunacy was designed...!
Unread 01-03-2009, 23:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Maybe we'll bring sunglasses to put on Toasty and see if it works?
(Toasty the Camera....)
Unread 01-03-2009, 23:44
AKA: Justin Chan
It seemed like Simbotics had some sort of sunglasses like feature on their camera, maybe someone could check on that.
Unread 01-03-2009, 23:52
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
The simbotics are using a fisheye lens.
Mentor 2415
Unread 02-03-2009, 07:10
AKA: Mark Anderson
We tried something like that by Friday afternoon.... =) Polarized and all. Can't say it helped I would suggest everyone play with some really strong, direct white lighting on their targets before heading to their regionals!
Unread 02-03-2009, 09:25
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We didn't use a Camera this year so I have no first hand experience with it's success or failure but I do know that someone published some Camera Threshold Values in the pits on Friday morning they were displayed next to the inspection station. Also, at about 7pm Thursday once all of the practice matches were over teams were let onto the Field for about 10 minutes each to test out Camera Settings. This is just what they did at Jersey, I don't know what'll happen at your Regional(s).
My suggestion to any teams who need to tune Cameras is to ask the FTA or someone else in power on the Field if there's any time when you could go out on the field to gather values. I've found that usually if you ask politely they'll try their best to help you out.
-Dustin Benedict
Unread 02-03-2009, 11:07
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We didn't do the camera calibration on Thursday, and regretted it. Our radar screen would show ghosted images of targets, but never a fully-solutioned target. The ghosted image meant that a pink/green combination appeared at that spot sometime in the last second, yet the data wasn't continuous. In other words, the targets would pop in and out while on the field, making them difficult to track. It still proved useful when we were close though.
We'll have to get it calibrated and practice with it in Florida.
GitHub
Unread 02-03-2009, 11:50
What is close? And did you succesfully target and shoot at that range?
Doug Leppard
team colors and misguided cameras bobbyt14 Programming 12 14-01-2009 10:00
Section 4.3.1<S03> and turrets JoelP Rules/Strategy 13 15-01-2006 11:23
Two cameras: Pros and Cons cooknl Programming 1 12-01-2006 20:57
S03 and turrets geeknerd99 Rules/Strategy 3 10-01-2006 22:35
On board cameras and vision systems and robots! oh my! archiver 2000 1 23-06-2002 23:02
