Go to Post Math, it's great stuff - AdamHeard [more]
Unread 02-03-2009, 13:23
GaryVoshol's Avatar
Cogito ergo arbitro
Re: possible solution to the static problem
Originally Posted by Tom Bottiglieri View Post
The FRP is non conducting, so there is no path from the robot to the ground while it is driving around. If you are driving full speed into a wall or airlock, there may not be enough contact with the carpet to discharge the build up into the ground before it contacts the field frame.
My thoughts as well. People were not reporting getting shocks when the robots were touched at the ends of the rounds. So any electrostatic charge that had built up was still there until grounded. The people on the FRP weren't grounded either.
(since 2004)
Solution to camera problem techkid7 Programming 1 12-01-2009 08:42
Onan Generator Control Problem - RC as solution? RyanN Electrical 8 01-12-2008 16:45
pic: Banebots carrier plates problem & solution Elgin Clock Extra Discussion 14 10-03-2007 07:50
