Go to Post We, as mentors, receive our greatest reward when our students become role models and give of their time to others in need. - Al Skierkiewicz [more]
Unread 02-03-2009, 00:10
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
A few questions for teams in week 1.
I know I'm probably gonna get a dozen "Read the manuals," but it's midnight where I am and I'm falling asleep so I was wondering if you could answer these please.
1) can any given team have 2 human players if the alliance agrees on that?
2) Do you pick robot starting positions or is your number (e.g. red 3) decide the starting location
3) Were the tongs useful, and if so was it often?
4) Is the traffic annoying as a driver, b ecause I saw a lot of traffic jams?
Thank You
p.s. again, sorry if 1 and 2 are in the manual.
Unread 02-03-2009, 00:16
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: A few questions for teams in week 1.
Every team must supply a human player, or that spot goes unfilled.
The robot starting positions are set by your alliance strategies, the field does not tell you where to start.
The tongs are required to be used to pick anything up off of the ground, if the tongs can reach it, it is legal.
Traffic might get annoying, but a good drivetrain and driver are able to get out of mostly anything.
1, 2, and 3 are in the manual FYI.
Thank You
1 is in the manual--you only get 4 players on the drive team, namely, 1 commander (can't touch the controls), 2 pilots (drivers), and 1 Payload Specialist (Definition of TEAM, 7.2).
2 isn't. I believe that, like the PS position, your alliance chooses this. I can be overturned.
3: Tongs are required by <G40-C>. No ifs, ands, or buts allowed. Also See <G40-D> and <G20-B>.
Unread 02-03-2009, 00:21
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
The traffic was pretty bad, but a good driver can avoid it. Generally the robots would cluster on one side or in the middle so if you can back out of that pileup you have half of the field to yourself for a few seconds.
Team 968 (Mentor) 2011
Team 1138 (Mentor) 2010
Team 1138 (Student) 2005-2009
Unread 02-03-2009, 00:35
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Let it be known, the tongs must be used, and they are very annoying to use an the heat of the moment... be prepared for that
Cold Fusion's 10th Season
Unread 02-03-2009, 23:45
Thank You. Again I know I probably read half of that stuff, but my brain was on meltdown. Thank You again.
www.sharkattack744.com
Unread 02-03-2009, 23:47
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
2) Red 1,2,3 dictates the players station number you're assigned to during the match, but robot starting positions are negotiated before the match within the alliance
4)Traffic, especially without the aid of a traction control system can get very annoying. I found that in many situations the worst traffic jams occour immediately at the start of teleoperated mode, because many teams have camera tracking autonomous programs that tend to cause a pileup of robots in one section of the field. Sharp turns, as imagined, were hard to control and there were a few situations that I found myself "pinned", more or less attached to another robot during front end collisions, because intake gaps hooked onto each other. Try to collide with other robots only on fully bumpered regions of your bot and you should be fine.
Unread 02-03-2009, 23:49
Lesman's Avatar
Lesman Lesman is offline
FRC #1014 (Bad Robot)
Lesman will become famous soon enough
Traffic-not a huge issue, though it reduced most fancy autonomous code to go forward and crash. But, pinning was a big issue, especially since wall to bumper applies more traction than wheels to ground.
Unread 03-03-2009, 00:07
Boron + Z Boron + Z is offline
FRC #1675
Boron + Z will become famous soon enough
4) One of the most ANNYOING things I found while driving had to be when there were a group of robots on your side of the field, right in front of you, while you're trying to drive on the opposite end of the field. It happened rarely, but when it did, oh man what a pain. The big green and pink trailer posts easily block a drivers vision, keep mobile and don't get stuck in the middle of a pack of bots. There's my Week 1 driver's advice.
A few questions Magnechu Rules/Strategy 8 25-01-2008 17:01
Looking for a few good teams jparkteach Off-Season Events 4 26-08-2006 20:24
Hartford is looking for a few good Vex Teams skimoose FIRST Tech Challenge 15 22-03-2006 22:59
A few questions... Ryan Dognaux 3D Animation and Competition 3 19-02-2005 22:48
Special Offer to Teams who Register for IRI in the next few days D.J. Fluck Chit-Chat 10 09-06-2002 18:12
