Go to Post This [Coach badge] means no-touchy the controllers. Even to save them from certain doom. - Kevin Sevcik [more]
View Poll Results: Was this useful?
Yes, it was! It helped point out diamonds in the rough 109 70.32%
No, its numbers generally did not correspond to robot's actual on-field performance 46 29.68%
Voters: 155. You may not vote on this poll
Thread Tools Rating: Thread Rating: 32 votes, 4.88 average. Display Modes
  #31   Spotlight this post!
Unread 01-03-2009, 20:44
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: Easy to use Offensive Power Rankings (OPR) program for mid-regional scouting
Originally Posted by Bongle View Post
Interpretations:
A high DPR might indicate:
-No-shows or broken robots that spend whole matches with a stopped trailer, thus getting filled up
-Robots that tend to get into positions where they get scored on
-Robots that tend to get their alliance partners into positions where they get scored on
-Robots with no auto mode
-Generally, high DPR means low mobility. It is a robot that gets scored on a lot.
High DPR can also mean that a robot purposely scored on his own alliance trailers to increase RS (ranking score) or to prevent a G14 violation.
I can tell you that we did this in 4 of our 7 Q-matches. And it got us the highest RS of all the 2 loss teams and allowed us to be seeded 4th. Without this strategy we would not have gotten to pick 1625 and and probably not have won the regional.
In one case we stopped scoring for ourselves with 30 seconds to go and scored about 40 points for the other alliance. So that also lowered our OPR a little bit. I think many the good veteran teams did this to some extent.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
  #32   Spotlight this post!
Unread 01-03-2009, 20:46
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Good points. I can't edit the first post anymore or else I'd add that.
  #33   Spotlight this post!
Unread 02-03-2009, 21:54
Bongle's Avatar
I guess this is up to v5 now. The only difference of any substance is the new prediction feature. Basically, this uses the OPRs computed so far to predict the remaining matches at a regional, and prints out the simulated rankings afterwards. If all the matches have been played, it does a self-analysis to see how accurate it would have been. Based on this, I can say that it is about 65-70% accurate when predicting after 40-50 matches, though this seems to depend heavily on the regional. It is much better at predicting GTR 2008 (80%) than it is predicting DC 2009 (55-60). Still, it is generally a good bit better than a coinflip.
Command-line is:
oprnet <regional> <year> predict <sort style> <quiet flag>
So...
oprnet il 2009 predict t q
or
oprnet dc 2009 predict t
or
oprnet oh 2009 predict
or
oprnet on 2008 predict (this has pretty cool results)
The main problem with predicting match results is that robots evolve quite a bit over the course of a regional. Some break, some get fixed, some get improved tactics or mechanical parts. Without actual 'on-the-ground' knowledge of what is going on with individual robots, any purely mathematical model is going to fail. Getting 65-70% of guesses right isn't bad. But still, the 'predict' feature is an entertainment-only kind of feature.
  #34   Spotlight this post!
Unread 03-03-2009, 10:23
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
In a command line:
oprnet (regional code) (year) (stat) > blah.csv
This uses the DOS redirect operator to send it to a text file. The stats are are tab-seperated so that you should be able to copy/paste it into excel and have all the cells line up properly.
I just tested this method with v.5. I needed to save it as a .txt file for Excel to open it correctly. No big deal.
I also noted that Excel sorted it backward. In other words, the highest ranked team was listed last.Again, this is no big deal and can easily be dealt with.
I'll test more to see if I can get Excel to import it in reverse sort order.
  #35   Spotlight this post!
Unread 03-03-2009, 10:32
Bongle's Avatar
Oh sorry, I forgot to fix that. I knew there was something requested...
  #36   Spotlight this post!
Unread 03-03-2009, 10:39
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Any OPR listing for BAE regional?
Like Aquidneck Island Robotics on Facebook!
  #37   Spotlight this post!
Unread 03-03-2009, 10:47
Bongle's Avatar
Nope, because the qualification matches have mysteriously disappeared.
  #38   Spotlight this post!
Unread 03-03-2009, 10:57
Fireworks 234's Avatar
Fireworks 234 Fireworks 234 is offline
Purdue FIRST Programs Enthusiast
AKA: Joe Tonte
FRC #3180 (Blaise of Glory)
Fireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of light
And Buckeye hasn't been updated yet, it's only got a few of the elimination matches in there and they don't even have the cities the teams are from for the awards yet.
Blaise of Glory - 3180
Previous History:
Member - Cyber Blue (234) 2004-2007
Mentor - Harrison Boiler Robotics (1747) 2008-2010
Mentor - Blaise of Glory (3180) 2011-?
Eagle Scout as of 10/19/2006
  #39   Spotlight this post!
Unread 03-03-2009, 11:40
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Any chase you can have it run a full report, something like:
il 2009 opr saa pm t > blah.csv
That way you can bring all the data in to Excel at once instead of running it multiple times.
-Oris-
  #40   Spotlight this post!
Unread 03-03-2009, 11:47
Bongle's Avatar
-Oris-
I'll add an "all" option tonight.
  #41   Spotlight this post!
Unread 03-03-2009, 12:02
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
attached is a Autohotkey script I wrote (compiled and main source) that grabs every event in the eventlist.txt file, and makes a .txt file of the results. The result file is already arranged as they will be in the "all" option.
Thanks for the continued updates.
Any way you can grab data from TBA when First's rankings aren't available? I guess you would need a lookup table from (year,event) -> TBA eventID.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2016)
Last edited by engunneer : 03-03-2009 at 12:03. Reason: helps to actually attach something
  #42   Spotlight this post!
Unread 03-03-2009, 12:34
Killraine Killraine is offline
Team Robot
AKA: Josh Lucas
FRC #2016 (Mighty Monkey Wrenches)
Killraine will become famous soon enoughKillraine will become famous soon enough
Am I correct in assuming that each of the following should be sorted (best -> worst) like this:
OPR: High (best) -> Low (worst)
SAA (DPR): Low (best) -> High (worst)
+/-: High (best) -> Low (worst)
If I am right, it seems that V5 sorts them wrong, sorting all categories as low -> high
  #43   Spotlight this post!
Unread 03-03-2009, 12:37
billbo911's Avatar
While you are adding options...........
Being that this app is dependent on FIRST updating their postings accurately and in a timely manner...
In the odd situation where there would not be access to that data (ie. no wifi available at the venue) or when FIRST has not updated it completely, is thee a way we could create our own file containing all the match scores and teams in each match from regional we are interested in and then have OPRnet point to that data source?
  #44   Spotlight this post!
Unread 03-03-2009, 12:44
Bongle's Avatar
Check my OPR thread from last year. That's how it used to work, and I decided it was an annoying way to do things, which is why this year's version has internet connectivity. Keep in mind you need about 30 matches before it starts being able to run OPR, so that'd be a lot of hand-entering.
I'll see about adding a TBA parser (it'd be pretty nice because TBA uses the same formatting for each year, unlike FIRST), but it looks like it'll be pretty annoying owing to the fact that TBA doesn't use the FRC acronyms for events so I'd need a big mapping from (year,event)->(tbaID).
Yep, that's on the to-do list.
  #45   Spotlight this post!
Unread 03-03-2009, 13:05
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
Anyone know what's going on with the official results from BAE? The only match results listed on FIRST's page are the elimination rounds, even those are not fully up-to-date.
2010-? - AIR Strike (Team #78)
2007-2009- Rhode Warriors (Team #121)
2003 - Team #190
1997-2002 - Bobcat Robotics (Team #177)
http://www.tomschindler.net
http://www.drivexc.com
Offensive Power Ranking Calculations Greg Marra General Forum 4 18-03-2009 22:03
Offensive Power Rankings for 2008 Bongle General Forum 166 18-05-2008 15:05
Offensive+Defensive Power Rankings BornaE General Forum 4 05-04-2008 01:33
2006 Offensive Power Ratings sw293 General Forum 16 10-05-2006 17:04
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
