Re: Joysticks with circular motion
I would suggest that you use one of the joystick controllers that allows yaw control by twisting the joystick.
We use this to control our crab/swerve drive... twist one way turn that way twist the other way and turn the other way... Just make sure and find one that will work with the present system. |
| Simulating Motion with Physical Dynamics | Madison | SolidWorks | 5 | 08-02-2007 12:19 |
| Placing inventor assemblies with motion constraints | rohit | Inventor | 2 | 03-02-2007 16:50 |
| Help with motion detector | chantilly_team | Programming | 13 | 31-01-2006 22:10 |
| Help - G-Code Circular Motion for CNC Milling | sanddrag | Technical Discussion | 15 | 18-08-2004 23:00 |
| Building a Clock with Periodic Motion | IMDWalrus | Math and Science | 15 | 24-03-2004 16:48 |
