Go to Post But their robot puts its wheels on one at a time just like ours, so we can be a HOF winner too! - Foster [more]
Unread 03-03-2009, 10:16
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Can you get the percent of compression you have?
Is it possible to get the amount of compression in the compressor in labview?
Answer fast please.
Unread 03-03-2009, 10:26
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Can you get the percent of compression you have?
Are you asking how to determine in software the amount of pressure in your pneumatics system? If so, you'd need to have a sensor called an analog pressure transducer, which you would screw into the pneumatics and wire into the analog breakout, and that would provide a variable reading proportional to the pressure in your system. Alternatively, you can just read from the pressure switch, but that will only tell you if you've reached the cutoff pressure (~115psi).
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 03-03-2009, 14:39
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
A pressure transducer would fit the bill. Understand that there is gauge pressure and absolute.
Unread 07-03-2009, 12:34
DonRotolo's Avatar
Back to humble
FRC #0832
Gauge pressure means 'relative to local atmospheric pressure' while absolute means 'relative to vacuum'. Either is fine for this purpose, but gauge pressure is what FRC is looking at (60 PSI).
the greatest gift you can have 1574aviad Chit-Chat 7 02-05-2005 22:36
can you get awards by devision edomus Championship Event 2 07-04-2004 01:05
What do you have to do to get? Tton General Forum 2 10-03-2003 11:13
how can you get more materials? Ydnar 3D Animation and Competition 5 01-04-2002 22:04
You have anything you don't like about the new forums? Ken Leung CD Forum Support 16 16-06-2001 15:37
