Go to Post Ok maybe you cant stop them, but you can utilize that pretty flashing LED pretty darn well! - Andy Grady [more]
  #31   Spotlight this post!
Unread 03-03-2009, 19:46
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: Watchdog!?!?!?!
A few notes on some of the things that have appeared in this thread:
1. I recommend disabling the watchdog entirely. This should be done by simply entering GetWatchdog.SetEnabled(false), NOT by "killing" the watchdog. That causes even more problems. I found this feature to be more of a pain than anything.
2. We have discovered that, if anything goes wrong in autonomous regarding code issues, you will be unable to retain control during teleop unless you reset, so resetting the system from the DS is critical. As such, we went through the process with our drive team. I highly recommend all programmers make sure that at least one driver knows how to do it. Wayne TenBrink posted instructions earlier on how that's done.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
  #32   Spotlight this post!
Unread 03-03-2009, 20:39
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Watchdog!?!?!?!
Watchdog's exist for a reason. I would not give a blanket statement saying disable the watchdog because for a number of teams this may be a bad idea. I know that there are parts of our robot that could be broken if our code were to hang and not be disabled by the watchdog.
For some teams disabling the watchdog may be the easy solution for now, but the "better" solution is probably a properly fed watchdog.
  #33   Spotlight this post!
Unread 03-03-2009, 20:47
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Re: Watchdog!?!?!?!
In any case, according to our programmers, not feeding the watchdog was the most common mistake in autonomous programming at Buckeye.
  #34   Spotlight this post!
Unread 03-03-2009, 21:15
All I do is twin.
AKA: elixir
Re: Watchdog!?!?!?!
We have not seen any problems arising from not using the watchdog, and we disabled it in all our code.
  #35   Spotlight this post!
Unread 03-03-2009, 21:26
StephenB StephenB is offline
no team (Team NI)
StephenB will become famous soon enough
Re: Watchdog!?!?!?!
either way works. the main reason the watchdog was put in was for debugging. if you hit a breakpoint, you might not want the robot to keep chugging along.
  #36   Spotlight this post!
Unread 03-03-2009, 21:27
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Watchdog!?!?!?!
Which is why I said it may work for some teams. We will not be disabling our watchdog because if our code is actually hanging somewhere we want the outputs disabled so our robot doesn't break itself or incur a penalty.
  #37   Spotlight this post!
Unread 03-03-2009, 21:44
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Re: Watchdog!?!?!?!
NI FIRST Support: FRC Robot Modes / States Explained
This is some documentation on these modes/states. Feel free to submit questions and feedback.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
  #38   Spotlight this post!
Unread 23-01-2010, 08:44
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
Re: Watchdog!?!?!?!
Glad to know we are not the only team struggling with programming. When using driver station we are able to connect to robot and drive sporadically, but have a watchdog not fed message. Does it have anything to do with the DS being so sporadic?
Also we have an ERROR Code 44015.
  #39   Spotlight this post!
Unread 23-01-2010, 08:52
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Watchdog!?!?!?!
We had a watchdog issue when our battery got too low.
In C++, the default code has something like
GetWatchDog().Feed()
at the top of the OperatorControl() loop. You need to make sure that that function gets called frequently.
In C++ (and probably all the other languages, since they are all the same library), the image analysis code seems to be a bit too slow to keep your watchdog fed if you put it in your main loop. I recommend you create a new task (aka thread) and do the image analysis there, putting the results in some variable accessible to the main OperatorControl() or Autonomous() loops.
That's what we're going to be doing today. I don't know the specifics of how we're going to do it yet, but I do know that the PIDController class spawns a new thread in its constructor, so we're going to be copying that.
WatchDog Timeout popo308 Programming 3 22-02-2009 22:04
Watchdog darty NI LabVIEW 8 16-02-2009 09:11
System: Watchdog problems dboisvert C/C++ 7 16-02-2009 02:36
System: Watchdog problems dboisvert C/C++ 1 15-02-2009 20:12
Watchdog Barchechath Programming 6 10-02-2007 20:05
