Go to Post looks like he was getting ready for a sprint! be careful chuck, its only like 2 feet from the line to the controls... - vivek16 [more]
Unread 08-02-2009, 08:13
Electrical Engineer
Rookie Year: 1995
Re: cuting plexi
Originally Posted by morganh2550 View Post
what is the most efficient way to cut plexi-glass
Although it has been hinted at in this thread, I wanted to be sure that you knew that Plexiglas is different than polycarbonate.
I know that the difference may appear to be semantic to us electrical types but it is important. If you hit Plexiglass with a hammer it will violently shatter whereas polycarbonate is so resilient that it is used in most saftey glasses you and your team wear in the pits...
The impact resistance of polycarbonate extends to tooling as well. Polycarbonate can be cut in a sheet metal shear, bent on a brake and drilled or machined easily. Plexiglas is not nearly as machinable.
My team always uses polycarbonate on our robots and we never use Plexiglass. This not only gives us a more robust robot but also increases the safety margin for the students working on the robot.
JMHO
Mike
Mike Betts
As easy as 355/113...
Unread 08-02-2009, 11:23
Dick Linn's Avatar
no team (Synergy)
Re: cuting plexi
And a tip on drilling - you can break the leading edges on the bit to prevent them from digging in and grabbing. See http://www.hawkfish.org/snailman/acrdrill.htm If you can find the untwisted drill bits that are used in the Yankee type push drills, they serve a similar purpose. This also works for brass.
A few drops of water with liquid dishwashing detergent in it will help as well.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 08-02-2009, 11:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: cuting plexi
JMHO
Mike
Mike I totally agree. I would never use plexiglas anywhere in my robot. I can get all I want for free but we still chose to purchase polycarbonate instead.
My company sells supplies for sign making. The reason I can get plexi free is because it is easily damaged in shipping and we always have the damaged pieces saved in our damaged goods rack. You won't find any polycarbonate in that rack.
Unread 08-02-2009, 14:10
Dick Linn's Avatar
no team (Synergy)
Re: cuting plexi
In a bind, Team 975 once used some of the "high strength" Acrylic. It was only moderately more durable than the regular stuff. No comparison to polycarbonate.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 09-02-2009, 09:19
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
Re: cuting plexi
Other than the table saw type stuff, we use a dremel with a spiral cutting bit (actually a Roto-Zip bit), with a straight-edge clamped to the material as a guide. Works very well.
BTW, don't inhale the fumes! Ventilate!
Cheers,
-Neil.
Unread 15-02-2009, 22:48
CPUgirl CPUgirl is offline
The Girl
AKA: Amanda
FRC #0964 (Bearcats)
CPUgirl is an unknown quantity at this point
Send a message via AIM to CPUgirl
Red face Re: cuting plexi
We always use polycarbonate and always use our bansaw when cutting it. Anything else is much more of a pain the only thing are the little shreds that you have to deal with but if you make sure to keep your mouth closed and of course your safety glasses on (probably semi-long sleeves too) and you should be fine. You grow used to it. Good luck.
Unread 16-02-2009, 01:40
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
Re: cuting plexi
I've found that using a dremmel with a high speed plastic cutting bit works really well, as long as you have a steady hand.
it's also nice since it lets you carve complex shapes.
be careful though, the fragments sent off from the dremmel are EXTREMELY HOT, and if you aren't careful, your arms get covered in little red dots from the burning plastic.
also, WEAR SAFETY GLASSES, they will save your eyes.
-Z
[center]
Unread 16-02-2009, 01:59
millerm277 millerm277 is offline
FRC #0041 (Robowarriors)
millerm277 will become famous soon enough
Send a message via AIM to millerm277
Re: cuting plexi
What we do: Big/straight cuts-Table Saw
Not possible to cut on a table saw-Band Saw
Too technical for either-Dremel, very slowly.
Thanks to: Anadigics and Knotts.
Unread 16-02-2009, 10:51
NC GEARS's Avatar
NC GEARS NC GEARS is offline
AKA: David Carrier
FRC #1918 (NC GEARS)
NC GEARS is an unknown quantity at this point
Re: cuting plexi
As everyone has said, leave the film on it. Our team uses a band saw and a table saw to do it. Any detailing, such as rounding corners etc, are done with a dremel. Be sure not to overheat it so it doesn't melt. If at all possible, get some Lexan. If your using the plexi I am thinking of, then its an acrylic material. Lexan is a polycarbonate material that doesnt break very easily. We learned not to use acrylic the hard way. Good luck to you though!
United States Coast Guard Academy
Class of 2014
Unread 16-02-2009, 11:53
Carlee10's Avatar
Carlee10 Carlee10 is offline
Loves F.I.R.S.T.!!!!!!
FRC #1529 (CyberCards)
Carlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to behold
Re: cuting plexi
Whatever you choose to do, do it very carefully!!!! I was working and unfortunately destroying plexiglass just the other day. You have to be very careful and gentle or it will break easily. I tried drilling a piece and cracked it, then was cutting another and managed to crack it,too. I was embarassed, and felt bad about ruining it. I won't be working with it anytime soon..... Good luck, though.
Attending- College!
Awards: BMR's 2008 Judges Award
"Courage is not the absence of fear, but rather the judgment that something else is more important than fear. The brave may not live forever, but the cautious do not live at all."- Movie quote
Unread 16-02-2009, 12:00
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: cuting plexi
Next time use polycarbonate (Lexan). It won't crack unless you spill Loctite or acetone on it.
Art Dutra IV
世上无难事,只怕有心人.
Unread 16-02-2009, 12:10
Carlee10's Avatar
Re: cuting plexi
I'm not sure what kind it was, but i didn't know it was so breakable. I tried to drill it without a guide hole, and it cracked. so we got more, and i was finishing the cut, and somehow managed to crack it again, even though I was being really careful. and the covering was on it.
Attending- College!
Unread 04-03-2009, 00:03
Dave Morris's Avatar
Dave Morris Dave Morris is offline
FRC #2016 (Mighty Monkey Wrenches)
Dave Morris is an unknown quantity at this point
Re: cuting plexi
Just use a jig saw and stay proud of your final cut line. Then use a hand held router with a bottom mounted bearing and clamp the plexi/polycarb to a straight edged countertop and trim it to final size. This easily works up to 1/2 inch thick if your router bit is large enough in diameter. We do this all day at work.
Unread 04-03-2009, 15:21
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: cuting plexi
this is the first thing a tell any rookie team
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 04-03-2009, 15:34
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: cuting plexi
Fast moving, fine tooth blade. Band saw is what we have used, we have also had luck with a circular saw.
pic: Team 2614's Cracked Plexi SlaminSwimster Extra Discussion 19 18-07-2008 00:10
plexi glass clatek Technical Discussion 13 29-01-2006 13:01
Will plexi-glass work? MathewSmith Technical Discussion 33 08-04-2004 07:17
Plexi-Glass walls Brett W Rules/Strategy 8 21-02-2003 22:44
