Go to Post Don't just assume that because you can modify an existing design that you are an engineer. - Daniel_LaFleur [more]
Unread 04-02-2009, 11:54
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Battery Display on DS
In the rules it states that we have to have the battery connected to the analog break out.
Originally Posted by <R64>
A National Instruments 9201 module must be installed in slot 1 of the cRIO Mobile Device
Controller. An analog breakout must be connected to this module. A jumper must be
installed on the “Battery Voltage” and “Power” pins on the analog breakout. The analog
breakout must be powered from the Power Distribution Panel. Please refer to Section 3.4 of
the “FRC Control System Component Data Sheets” for information on these connections.
and then it refers to this
Originally Posted by 3.4.2
1) Plug the Analog Breakout module into an NI 9201 analog input module and secure with
screws
2) apply power to J3 from the PD via 5A breaker and smaller WAGOs
3) select whether AI8 is to be connected to the 3x8 header or input power for battery sensing
and apply jumper accordingly
4) attach sensors via 3-pin PWM to the 3x8 header with careful consideration of polarity
Now here is the problem. Is the battery voltage suppose to show up next to "Battery" on the DS? We have done all these steps and it still says 00.00v but then when we read the analog input of AI8 it comes up as 7(ish)v which is about 40% of the 12v(as stated in the Q&A right below).
Spent a good amount of time searching, but didn't find anything that was really relevant to this.
Unread 04-02-2009, 12:03
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: Battery Display on DS
Wow, this is a really good point. I'm sorry I dont know how to help, but in reading this I realized that we have had the same problem... I think... I will check on the robot tonight to see how ours is and let you know if we got it to work...
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 04-02-2009, 12:10
I thought the resource reservation system wouldn't allow you to get clean access to AI8:1. How are you accessing this data?
Unread 04-02-2009, 12:15
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
What else is the Driver Station displaying? Enabled/Disabled/No Comms/No Code? What about the RSL state?
Russ
Unread 04-02-2009, 12:16
Yes.
7(ish) is not 40% of 12.
Are you certain you have battery power coming from the Power Distribution to the Analog Breakout? Measure on the white WAGO connector on the breakout to make sure. You might have one of the WAGO connections hitting the insulation instead of the conductor on an insufficiently-stripped wire.
(Note that you must use a 20A breaker, not a 5A one.)
Unread 04-02-2009, 12:32
Boydean's Avatar
The Blue Alliance
Originally Posted by Alan Anderson View Post
Yes.
Yes, we do have power going to the breakout via a 20amp breaker.
Enabled, displays No Comms No Code when it first starts up then goes to 00.00v and stays. Does the same thing with autonomous enabled. We have been been running programs on the cRIO since the start of the season. Everything is updated and what not. I just noticed that this was happening the other night and couldn't find anything about it.
Note -- We have been changing out the battery and no change.
Unread 04-02-2009, 13:13
Does the DS ever change to not show "no comms" or "no code"?
I'm suspicious about whether you're using the templates and initiating the system as required. Have you followed the very detailed step-by-step procedures to bring up the system from the OTB condition?
Russ
Unread 04-02-2009, 13:39
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
You may have a problem with the analog bumper, try swapping out the one you have connected. I know this worked for another team.
Unread 04-02-2009, 13:41
Is the power LED on the Analog Breakout lit?
Russ
Unread 04-02-2009, 13:57
Jared Russell's Avatar
Taking a year (mostly) off
We also cannot seem to get the battery reading working. Honestly, it's been low on our list of things to do for awhile, but tonight I'll take a look and try to figure out what's going on.
We did RTFM. I'll try the other bumper tonight.
Unread 04-02-2009, 13:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Ours has been working fine. I'd suggest looking again at Alans ideas above....
Unread 04-02-2009, 14:10
petet4 petet4 is offline
AKA: Pete Thomas
FRC #0706 (Cyberhawks)
petet4 is on a distinguished road
Sometimes a picture helps. With the following connections and default code loaded the battery voltage should should be displayed on the DS.
-pete
Unread 08-02-2009, 16:53
StephenB StephenB is offline
no team (Team NI)
StephenB will become famous soon enough
It reads ~7ish volts because the input range on the cRIO AI module is -10V to 10V. So there is a voltage divider on the analog bumper input 8 to bring battery voltage down within this range. The cRIO software knows this so it reports the actual battery voltage after it does the math to undo the voltage division.
Unread 04-03-2009, 19:09
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
I'm also having a similar problem. the system boots up and the voltage reads 0.00v. I'm not sure what to do because I have followed all the instructions discribed. It's getting really close to our first competion and i'm getting nervous that it's not working. Can some please reply if you have figured out this problem.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Interacrtive Display PUFIRST Chit-Chat 1 09-04-2008 15:29
OI Display problem? Shu Song Control System 4 01-02-2005 20:42
OI Display problem? Shu Song Electrical 4 01-02-2005 20:42
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
LCD display James Crivellone Rules/Strategy 6 06-01-2002 10:22
