| View Poll Results: Did your team use the Camera? | |||
| No |
19 | 28.79% |
| Yes |
47 | 71.21% |
| Voters: 66. You may not vote on this poll | |||
Re: Is anyone using the Camera?
An appropriately compressed 160x120 image is 1300 - 1800 bytes. We fit each image over two packets, along with a pretty decent amount of telemetry. 160x120 is a bit small, so we stretch it to 320x240 on our Dashboard. Because the eye integrates video very well, it's much more than usable for the driver. |
We're certainly using the camera to track the targets and automatically aim our turret, unless the programmers decide to stream video from it. Whichever one is easier is the one we're going for.
The camera we have programmed on our robot tracks opposing trailers, chases after the trailer, then when it gets about a foot away starts the belt holding the moon rocks and dumps it in. The program worked actually really well at the DC regional, except for 2 or 3 times were the camera lost patience or the target for whatever reason.
We had the camera sending video back to our laptop at the control station and it was pretty much seamless, i was expecting it to be really bad refresh rate but we had no trouble with it at Traverse city.
We had a couple of software issues at start of the DC Regional, but as the tournament went on, I was assured it was working. Since we did not have a chance to fully test it out on the practice field, we choose not to use it and relied on manual control of the turret and shooter. We expect to have it up and running at Chesapeake, however. We will still have the turret under manual control until just before firing, when we will allow the camera to lock on the target and then fire.
We used our camera at Trenton along with a few other sensors that we'll try to perfect at Philly. At the moment we've only risked trying to score 2 balls in autonomous while placing the other 5 in our conveyor ready to load the hopper in teleop. We were extremely proud of our programmers for making it track very well.
#7
we're using it,
we have it working perfectly All Zach has to do it aim the turret towards a trailer, and then the camera takes over and follows it. |
#8
We're having some difficulties with the camera.
It's working, but response time is ridiculously slow (> 0.5 seconds). I'm not quite sure what's causing it. I'm just using the FindColor() function provided in the API, and I even tried to speed that up by allowing multiple calls to use the same image (so that you don't have to get a new image for each call). Still no luck. The only thing thing that I can think of as the cause is that I'm using a multi-tasking system (the drive train, collector system, and shooter system all have their own tasks, using a buffering system of my design). I don't see how they would be slowing things down to that point, however, as all other tasks have very fast response times ( < 0.05 seconds). Any ideas what may be the problem? |
#9
we have a gyro and accelerometer and 7 motors all running and there's no delay.... is it on a rotating turret? we had this problem, but solved it by decreasing the speed of the rotation and now it lock on in under .5 second from 6 feet.... although our camera is set to only track pink.... Last edited by gorrilla : 05-03-2009 at 21:41. |
#10
We are using sensors. We have 4 encoders hooked up to the drive train (we're using an omni system). It's not the lock-on that's the problem. I could tune that fairly easily. The problem is the actual return rate of the function I'm using to get target data. I've put in some prints for debugging and the actual function only returns at > 0.5 seconds. The actual tracking works perfectly; the problem is that it's too slow.
I'm planning on trying an approach closer to what is used in the two color demo. We'll see if that gives us any luck. |
| Anyone using the Accelerometer ? | de_ | Sensors | 1 | 27-11-2009 14:44 |
| Getting the Image from the Camera Using Windriver (C++) | computerish | C/C++ | 0 | 17-01-2009 16:03 |
| Where do I begin to get the robot to move using the camera? | Ianuser | Programming | 10 | 16-02-2007 17:55 |
| Using Easy C to program the camera. | Tazlikesrobots | Programming | 5 | 19-02-2006 21:33 |
| Is Anyone Using Motors to Hoist themselves off the platform on the bar? | xxlshortys | Motors | 36 | 25-02-2004 01:06 |
