Go to Post Andy sent me this message last year: "you go, Jenny." I'm still waiting for him to say it's ok to stop. - RoboMom [more]
View Poll Results: Was this useful?
Yes, it was! It helped point out diamonds in the rough 109 70.32%
No, its numbers generally did not correspond to robot's actual on-field performance 46 29.68%
Voters: 155. You may not vote on this poll
Thread Tools Rating: Thread Rating: 32 votes, 4.88 average. Display Modes
  #46   Spotlight this post!
Unread 03-03-2009, 13:17
Killraine Killraine is offline
Team Robot
AKA: Josh Lucas
FRC #2016 (Mighty Monkey Wrenches)
Killraine will become famous soon enoughKillraine will become famous soon enough
Re: Easy to use Offensive Power Rankings (OPR) program for mid-regional scouting
Also, since the scores are getting sorted anyway, could you add an actual number rank (ie highest opr would be 1, next would be 2, etc.)?
  #47   Spotlight this post!
Unread 04-03-2009, 19:12
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
v6:
-Sorts OPR, SAA, and PMs in a more logical manner
-New 'all' statistic type that prints out OPR, SAA, and PM in a table. Different output for the console window versus command-line running so that you guys running it for excel will get your tabs, while the console-window people will still be able to read it.
  #48   Spotlight this post!
Unread 05-03-2009, 11:21
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Looks good...
When you try the following the Pos is just in numerical order:
OPRNet.exe il 2009 all t q > all.txt
Any chance you can have it show their Rank instead?
-Oris-
  #49   Spotlight this post!
Unread 05-03-2009, 11:43
Bongle's Avatar
Originally Posted by Oris View Post
Looks good...
-Oris-
Rather than 't' (for sort-by-team), use 'r' (for sort-by-rank). That'll sort the table by OPR first, though if you want to sort it, I'd recommend copying the contents of all.txt into excel and sorting there.
  #50   Spotlight this post!
Unread 05-03-2009, 12:40
Team Robot
AKA: Josh Lucas
When I sort +/- by rank, the highest ranked team is rank "0" rather than "1"
Edit: Also, it would be nice to be able to sort by team, but still see what rank the teams are when sorted by rating. Ie. Sort by rating first to get a rank value for each team, then resort by team number. I know its not really necessary if you just take the data and put it in excel, but it would be nice for the program as a stand alone.
  #51   Spotlight this post!
Unread 05-03-2009, 13:07
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Bongle -- do you mind if I port this over to Java? I want to try to get a real-time OPR Scoring program working by the time Atlanta rolls around.
2017 Scoring Model
CAD Library | GitHub
  #52   Spotlight this post!
Unread 05-03-2009, 13:16
Bongle's Avatar
Go ahead. If you're running it from a server, I think it'd be easiest to just run oprnet once each match is done and parse the results. Porting the math stuff might be hard.
  #53   Spotlight this post!
Unread 06-03-2009, 09:56
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
I have a general question that I would love for you all to consider. I am a firm believer in the OPR/DPR concept, and included it in our team's scouting application. But what I found was that in this game, ALLIANCE data in a match is not that helpful. If a really good team has an alliance with two essentially non-functional robots in 2 or 3 of your matches - the numbers look terrible for that team. A case in point, 234 (Cyberblue) at the DC regional - if you look at the OPR numbers for them, they are in the middle of the pack. Our scouting team did NOT look at the alliance data this year. I had scouts answer the following questions:
1) How many MR did they place in a trailer (including their own in the event they were trying to avoid the penalty)
2) How many MR were in their trailer (by either the opposing alliance, or the HP)
3) How many EC did they deliver to be exchanged with a SC
I then calculated the OPR and DPR on those stats. In my example above, regarding 234 - they jumped from middle of the pack, to essentially the same level as 45, which is where they should have been ranked.
Any one else looking at TEAM OPR and DPR, and if so, how are you doing it, and what were your results like.
By the way, when I looked at the predictive nature of the values we calculated, we were right in our predictions more than 85% of the time. Only something like "forgetting to turn on the radio" or some such issue would throw off the results.
Best regards,
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
  #54   Spotlight this post!
Unread 06-03-2009, 10:11
Bongle's Avatar
Any team that scouts entirely off of the output of this program (or any OPR program) is doing something wrong. Personally, I use it to get a quick idea of which robots to watch if I'm watching a webcast and haven't been following an entire regional. I completely second your recommendation of in-person scouting. Just like the FRC rankings system often fails an otherwise good team, the OPR ranking algorithm can screw up too.
That's not necessarily true. If your two non-functional alliance partners are consistently non-functional, then your OPR should be unaffected. The main thing that throws off OPR is inconsistency. If an very good team has a battery fall out during a match, then it affects their alliance partners' OPR scores quite badly, because it 'looks' to the algorithm like their presence resulted in a massive reduction in their alliance's score.
  #55   Spotlight this post!
Unread 06-03-2009, 11:27
Team Robot
AKA: Josh Lucas
If only we could have some kind of "fluke" marker that we could place on team's whenever they behave inconsitently. I don't know your algorithm, but maybe it could treat a fluke robot performance as a no-name default robot that performs at the low level it does.
  #56   Spotlight this post!
Unread 06-03-2009, 13:58
JesseK's Avatar
FRC #1885 (ILITE)
Surprisingly, I got alot of the backbone of the porting done last night. Luckily Jama makes a Java library as well. I may have a first pass at it completed by the end of the weekend. All I have to do is figure out this silly URL issue...
2017 Scoring Model
  #57   Spotlight this post!
Unread 06-03-2009, 14:14
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Oh, how I understand you!
I'm working on a MATLAB version since last night and the math is all working IF you input the data (copy from FIRST to Excel then to MATLAB, really easy but cumbersome). Coding to parse the results from FIRST's website is going to take the full weekend, I believe.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
  #58   Spotlight this post!
Unread 06-03-2009, 14:20
Bongle's Avatar
That depends on how flexible you want your parsing to be. I spent 2 hours trying to write an uber-XML parser with MSXML, then I gave up and spent about half an hour hacking together the one that I use now. All of FIRST's score pages from mid-2008 onwards are generated from the same application, and have identical formatting. I just read one line at a time and looked for the text that always preceded a team score. It works well enough for me, though it'll need an update if they ever change their match results page style.
Better idea, if you're not already committed to scraping from FIRST: scrape from TBA - they use the same style for all events, all years. Your program would be able to run OPRs all the way back to 2006.
Edit: Speaking of parsing, I notice that the prediction code doesn't work with a regional underway. I'll have to look at that tonight (I wasn't able to properly test it since all regionals were done when I initially wrote that feature).
  #59   Spotlight this post!
Unread 08-03-2009, 00:31
Manoel's Avatar
You, sir, are wise.
As a professor used to say, there are always at least two ways to solve a problem. More often than not, the easy ways are not correct and the correct ways are not easy. We chose easy, so eventually it will come and bite us.
I used TBA data so you can get stats for events from 2006 to 2009. It's nearly impossible to obtain a 2007 event matrix that's not ill-conditioned - I believe it's due to FIRST's awful alliance sorting algorithms from that year, but have not looked into in detail. In short, OPR for 2007 will not work. If someone is feeling reminiscent this days, please take a look.
Here's the code, just run OPR from MATLAB's command window and ask for what you want. The script returns three arrays containing ranked OPR, DPR (or whatever you might call it) and +/- stats for that particular event.
I have tested it with several events, but bugs may arise. Please test and let me know.
Brazilian Machine
Team # 383
  #60   Spotlight this post!
Unread 08-03-2009, 09:31
Bongle's Avatar
You, sir, are wise.
It is probably a combination of the terrible alliance picking, and that 2007 had non-linear scoring. A robot that always scored 3 ringers in 2007 might contribute 6 points in one match (by scoring 2 points, 3 times), or it might contribute 192 points in another, by extending a row of 5 into a row of 8.
In 2006, 2008, and 2009, a robot that did <game action> 5 times in each match generally generated the same number of points.
Offensive Power Ranking Calculations Greg Marra General Forum 4 18-03-2009 22:03
Offensive Power Rankings for 2008 Bongle General Forum 166 18-05-2008 15:05
Offensive+Defensive Power Rankings BornaE General Forum 4 05-04-2008 01:33
2006 Offensive Power Ratings sw293 General Forum 16 10-05-2006 17:04
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
