Go to Post Yes, it is fun. Its fun to watch the students expand their thinking and look outside the "normal" and watch their thoughts explode! Its also fun to watch the mentor's minds fry trying to out think the students.;) - Robert Cawthon [more]
View Poll Results: Did your team use the Camera?
No 19 28.79%
Yes 47 71.21%
Voters: 66. You may not vote on this poll
Unread 05-03-2009, 15:09
Re: Is anyone using the Camera?
We used our camera at Trenton along with a few other sensors that we'll try to perfect at Philly. At the moment we've only risked trying to score 2 balls in autonomous while placing the other 5 in our conveyor ready to load the hopper in teleop. We were extremely proud of our programmers for making it track very well.
Unread 05-03-2009, 15:16
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
we're using it,
we have it working perfectly
All Zach has to do it aim the turret towards a trailer, and then the camera takes over and follows it.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 05-03-2009, 18:27
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
We're having some difficulties with the camera.
It's working, but response time is ridiculously slow (> 0.5 seconds). I'm not quite sure what's causing it. I'm just using the FindColor() function provided in the API, and I even tried to speed that up by allowing multiple calls to use the same image (so that you don't have to get a new image for each call). Still no luck.
The only thing thing that I can think of as the cause is that I'm using a multi-tasking system (the drive train, collector system, and shooter system all have their own tasks, using a buffering system of my design). I don't see how they would be slowing things down to that point, however, as all other tasks have very fast response times ( < 0.05 seconds).
Any ideas what may be the problem?
Unread 05-03-2009, 21:26
gorrilla's Avatar
AKA: adam spears
are you using any sensors?
we have a gyro and accelerometer and 7 motors all running and there's no delay....
is it on a rotating turret?
we had this problem, but solved it by decreasing the speed of the rotation and now it lock on in under .5 second from 6 feet....
although our camera is set to only track pink....
Adam Spears
Unread 05-03-2009, 21:52
slavik262's Avatar
AKA: Matt Kline
We are using sensors. We have 4 encoders hooked up to the drive train (we're using an omni system). It's not the lock-on that's the problem. I could tune that fairly easily. The problem is the actual return rate of the function I'm using to get target data. I've put in some prints for debugging and the actual function only returns at > 0.5 seconds. The actual tracking works perfectly; the problem is that it's too slow.
I'm planning on trying an approach closer to what is used in the two color demo. We'll see if that gives us any luck.
Anyone using the Accelerometer ? de_ Sensors 1 27-11-2009 14:44
Getting the Image from the Camera Using Windriver (C++) computerish C/C++ 0 17-01-2009 16:03
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
Using Easy C to program the camera. Tazlikesrobots Programming 5 19-02-2006 21:33
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
