Go to Post ...the list of the things we want to get done in the off-season has grown to such a length that I have to take off my shoes and socks to count them...and I think I may need to grow a few more toes soon. - StephLee [more]
Unread 05-03-2009, 17:56
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Re: Over Exposure
We used sun glass lenses over our camera(s) a couple years back, That might help what I think you guys are having problems with.
Unread 05-03-2009, 18:00
ChaosX73 ChaosX73 is offline
AKA: Ryan Harrison
FRC #2338 (Gear it Forward)
ChaosX73 is a glorious beacon of lightChaosX73 is a glorious beacon of lightChaosX73 is a glorious beacon of lightChaosX73 is a glorious beacon of lightChaosX73 is a glorious beacon of light
Re: Over Exposure
My dad was thinking of doing something like that, and it might work
Unread 05-03-2009, 18:38
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Over Exposure
Check out the last 2 pages of this thread for some tips and procedures for working with the camera.
Unread 05-03-2009, 22:32
Re: Over Exposure
As mentioned in the other thread, look to adjust brightness as the primary way to reduce glare. Because of light being in the frame, it was also necessary to lower the minimum saturation threshold value a bit.
As for sunglasses, the vision term they'd use is called a neutral density filter, it just means an uncolored filter that blocks some light without tinting the result. I haven't tried it explicitly, but I believe this will simply cause the camera to increase the exposure time further, causing more blur and slower response while still having too much glare on the targets. Of course if you try one out and find a good way to use it, I'd be happy to hear about it.
Greg McKaskle
Unread 05-03-2009, 22:38
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Re: Over Exposure
May I suggest a polarized lens. Buy a semi-cheap pair of polarized sunglasses, pop out the lens and fit it to your camera. Rotate the polarization to the angle best suited for eliminating the field glare.
Unread 11-03-2009, 07:23
Re: Over Exposure
This was a good idea. I finally got around to trying it, but without the cheap sunglass part. I used a directional polarizer for still photography, and it pretty much cuts everything evenly. Unlike sunlight, the floodlights aren't polarized. It turns out that the surface effect producing the glare is still unpolarized. That means that the polarizing filter acts as a neutral density and once the camera adjusts to let in more light, you still have glare.
Greg McKaskle
Unread 11-03-2009, 08:05
Re: Over Exposure
In addition to the neutral density filters you can also try a method called "barn dooring" simply add shields to prevent the glare from entering the camera. If you go to a good camera shop or online store, you can ND filter material in a sheet film form. Simply cut the sheet in small pieces and add them in layers to the front of the camera until you get the desired effect. Search for neutral density lighting gel.
Unread 11-03-2009, 08:10
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: Over Exposure
Try a polarized piece of plastic over it. You can get polarized sun glasses for fairly cheap if you do not care about style.
Legal? Hurdling Over Overpass and Over Lane Divider 7-11number1 Rules/Strategy 11 20-01-2008 14:58
Throwning the ball over the over Pass eastsideboma Rules/Strategy 16 15-01-2008 12:56
Do you need the exposure values? Code\\Pilot Programming 5 20-02-2005 20:08
More exposure for Dean Greg Ross General Forum 15 26-01-2002 03:24
Some real exposure FIRST in ASME newsletter! Elgin Clock General Forum 1 23-01-2002 16:34
