Go to Post Aww, but I ENJOY getting all up in arms about something that's ultimately inconsequential! - Cothron Theiss [more]
Unread 05-03-2009, 20:39
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Team1710 is an unknown quantity at this point
Swerve Drive
Just wondering if I could get an inventor drawing of a swerve drive. I'm designing one now and would like to get some input on sizing stuff.
Unread 06-03-2009, 01:26
CraigHickman
Posts: n/a
Re: Swerve Drive
I'd be glad to send you a CAD of one of my crab designs, but they're on my hard drive back home and I'm at competition. I'll get back to you once I get home, and shoot it to you.
-Craig
Unread 06-03-2009, 01:46
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: Swerve Drive
-Craig
Craig, could you send me one of these also? Ramones.rock@gmail.com
Unread 06-03-2009, 02:09
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: Swerve Drive
Hmm... You should post it as an attachment (or provide a link..)
I think A LOT of people will ask, including me
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 06-03-2009, 10:05
Team1710's Avatar
FRC #1710
Re: Swerve Drive
Yea I'll post an image of what I have currently. Also What type of wheels should be used in a crab drive? Right now I'm basing it off of this year's wheels but I doubt next year will have wheel restrictions.
Unread 06-03-2009, 11:10
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Re: Swerve Drive
well of course, you'll want to be able to turn the wheels with relative ease, but you wouldn't want to use something like this year's wheels because the coefficient of friction is a little too low.
Unread 06-03-2009, 12:03
CJmango's Avatar
CJmango CJmango is offline
AKA: Christopher Jones
CJmango is an unknown quantity at this point
Send a message via AIM to CJmango
Re: Swerve Drive
You're right to take that into consideration. In 2002 traction was everything and my team built a crab drive with 2 wheels in each corner. What's worse, we had a coefficient of friction around 1.6!. That thing could pull, but we were burning out our motors and stripping gears trying to turn. Taking off one of the wheels on each housing we were able to turn more effectively, still with a 1.6 uf. The wheels were off the turning center of the housings, though, and I'm sure that helped. We also restricted our major turning to when the robot was in motion, which does take away some of the advantage of crab.
The following year a similar design worked with the wheels in line with the turning center although we eventually moved away from the high traction material because it wasn't as necessary.
It's actually probably a misconception that you need low traction wheels in general for crab. If anything, crab allows you to have high traction on all wheels because the wheels don't have to slip sideways like they do in tank drive. You just have to keep in mind the force required for stationary turning, just like turning the wheels on your car when the car isn't moving.
Unread 06-03-2009, 14:45
Team1710's Avatar
FRC #1710
Re: Swerve Drive
I thought there needs to be just enough traction to allow the turning of the wheels. High traction wheels would just rip to shreds with that kind of turning.
Unread 06-03-2009, 19:42
CraigHickman
Posts: n/a
Re: Swerve Drive
This argument has been beaten to death. Check out other crab threads for more info on this idea...
Unread 07-03-2009, 04:00
CJmango's Avatar
Re: Swerve Drive
In crab you don't turn the wheels much more harsly than you do with car steering, and you definitely don't drag them sideways. With tank steer the wheels actually have to skid horizontally in order for the bot to turn. With crab, you rotate the wheels in place, so where the friction gets you is torsion on the tread in contact with the ground. This is no different than front wheel steering and it's not a ton if you have regular wheels. If you go to high-traction wheels you just have to make sure you're moving at least a tiny bit when you turn large angles or you could run the rist of tearing tread just like you can tear your car tires if you turn the steering wheel too much when the car isn't moving.
There really is no reason to shy away from high traction tires. The robot I mentioned in my prior post had 4 wheel crab and could out pull any robot at the championship that year, I'm betting even the Beaty walker.
Unread 07-03-2009, 04:47
Galum's Avatar
Galum Galum is offline
AKA: Gal Barkai
FRC #1657 (HaMosad)
Galum is on a distinguished road
Send a message via MSN to Galum
Re: Swerve Drive
http://hamosad1657.net/inventor/Chassis.html
Viewed via Freewheel, I can give you the DWF or answer questions if you'd like, just tell me.
Unread 07-03-2009, 09:58
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: Swerve Drive
Wow, that is a very cool website, and great CAD.
Swerve drive 4, 2+2? kirtar Technical Discussion 18 02-04-2008 06:58
A Swerve Drive Question lndnny Technical Discussion 10 20-07-2006 08:09
Swerve Drive on a Jeep Karthik Math and Science 3 01-02-2005 17:50
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
