Re: Labview Autonomous and Pneumatics
From your description I'm assuming you're using the Watchdog "Delay and Feed" to drive straight for 10sec. If you stay with "dead-reckoning" (i.e. driving for certain times rather than based on some sensor input like an encoder or a gyro), you can wire off of the "Delay and Feed" error output to have subsequent VI's (like firing a solenoid) run after the delay has expired. This accomplishes basically the same thing as a sequence structure or state machine for very simple sequences.
Make sure you've opened the solenoid outputs before your Auto runs - in the LV advanced framework you can do that in the Begin vi, and add the solenoid refs to the Robot Data cluster. Hope that helps. Ron Teams 2607 - software mentor |
| Labview Autonomous AND Teleop | Two-Face | Programming | 1 | 14-02-2009 18:33 |
| Basic autonomous on LabView | Timshel | Programming | 0 | 30-01-2009 13:10 |
| New TipJar Training Video - Autonomous Mode and LabVIEW Training Giveaway | LVMastery | NI LabVIEW | 3 | 28-01-2009 07:06 |
| Autonomous mode in Labview | PinionTwister | NI LabVIEW | 3 | 10-01-2009 12:50 |
| Autonomous questions (Labview) and some general issues | Daniel_H | NI LabVIEW | 15 | 08-01-2009 21:07 |
