Go to Post I will gladly be pied if that's something you guys want. I know I have people from the Clarkson FIRST dorm floor who will shell out PLENTY of cash for the chance to pie me in the face! - Libby K [more]
Unread 06-03-2009, 09:19
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Labview Autonomous and Pneumatics
I tried a forum search and came up with nothing-
Would anyone have a code snippet or could explain to our students how to trigger pneumatic cylinders in autonomous mode? We currently *(as has been explained to me) have a watchdog timer that runs for 10 seconds to go straight.
Our drive system uses pneumatic cylinders to steer- so until we figure out how to turn we'll just go straight.... into the wall
Thanks in advance! (Posting from the competition now...)
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 06-03-2009, 09:31
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Labview Autonomous and Pneumatics
It's exactly the same as tele-operated mode. Are they having trouble making it work in autonomous mode?
Twitter Profile
Unread 06-03-2009, 12:13
I suspect the issue you have is getting the reference to the relay or spike so that auto can control it. You can do this by modifying the Robot Global and writing the refnums in Begin or outside of the loop in basic. Then read the global in Auto and control it. Use error I/O for sequencing, or sequence structure if you must.
Greg McKaskle
Unread 06-03-2009, 12:19
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
From your description I'm assuming you're using the Watchdog "Delay and Feed" to drive straight for 10sec. If you stay with "dead-reckoning" (i.e. driving for certain times rather than based on some sensor input like an encoder or a gyro), you can wire off of the "Delay and Feed" error output to have subsequent VI's (like firing a solenoid) run after the delay has expired. This accomplishes basically the same thing as a sequence structure or state machine for very simple sequences.
Make sure you've opened the solenoid outputs before your Auto runs - in the LV advanced framework you can do that in the Begin vi, and add the solenoid refs to the Robot Data cluster. Hope that helps.
Ron
Teams 2607 - software mentor
Unread 06-03-2009, 20:56
AKA: Jason
FRC #3015
Ron
Thanks Ron-
I had the students and the other mentor take a look at the note. They seemed to have an idea as to what it might be- but I'll just smile and nod and pull out the p-card....
Labview Autonomous AND Teleop Two-Face Programming 1 14-02-2009 18:33
Basic autonomous on LabView Timshel Programming 0 30-01-2009 13:10
New TipJar Training Video - Autonomous Mode and LabVIEW Training Giveaway LVMastery NI LabVIEW 3 28-01-2009 07:06
Autonomous mode in Labview PinionTwister NI LabVIEW 3 10-01-2009 12:50
Autonomous questions (Labview) and some general issues Daniel_H NI LabVIEW 15 08-01-2009 21:07
