Go to Post Can we just get over this inane lawyering of the rules and get back to building robots? . - dlavery [more]
Unread 07-03-2009, 10:51
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
2009 Human Player Specifics
Got some specific questions about what people are seeing on Human Players.
The rules say the HP must use the tongs to pick up the balls from the floor. Is this ANYTIME? Even if the balls are past the airlock and behind the wall?
Like if the ball rolled through the air lock and past the driver wall, does the HP still have to use the tongs to pick up the ball from the floor?
Are you guys seeing any penalties for reaching on the floor for balls past the driver wall without using the tongs?
Once they use the tongs and place the balls in the tote (for later retrieval), then they can reach in the tote with their hands and get balls is what I read in the rules.
Can HP hold more than one ball? I don't see anything in the rules against this yet I don't see many HP doing this. Didn't know if I missed a rule somewhere.
Can human players toss a ball under the wall through the airlock back to the robot without penalty without using the tongs? I think I seen Simbots doing this but wasn't sure.
Thanks for any feedback on specific ball handling on the HP.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 07-03-2009, 11:01
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: 2009 Human Player Specifics
HP must use tongs for any ball that is not in the tote
I have seen penalties be given for not using tongs
HP can hold more than one ball
At midwest I saw at least one instance of an entire tote being dumped under the wall toward a robot.
Also at Midwest, supercells were loaded into robots by sending them under the wall.
Unread 07-03-2009, 11:07
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
That was a short break
FRC #2826 (Wave Robotics)
Team Role: Electrical
It was a rule or an update that states that the tote that holds the balls must remain on the floor at all times.
yep here it is
http://usfirst.org/uploadedFiles/Team%20Update%208.pdf
2012-2016 Wave Robotics Team 2826
Unread 07-03-2009, 11:11
Chains=Fun
Hmm, that's weird. Trust the rule updates, not other regionals.
Unread 07-03-2009, 11:17
There are only 3 refs this year and they don't really watch the HP's that well, as they are watching the field making sure the robots aren't breaking rules. At TC there were SO many HP penalties that didn't get called because the refs just weren't watching at that time. 3 refs for this game really is WAY to few.
Unread 07-03-2009, 19:36
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
The airlock includes the case/enclosure inside the driver station wall, not just outside the wall. Tongs must be used to lift the ball off the ground, then once removed from the airlock it is free for use. Put it in the tote, hold it in your hand, drop it on the ground outside the airlock. You no longer need to use the tongs. Payload specialists can hold as many as they want at once, but can't touch them until after the match starts.
Wetzel
Viva Olancho!
Unread 09-03-2009, 19:07
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
I can understand your concern, however, if everyone is volenteer then shouldn't you be lucky that you have 3 referees? It would be more convenient and more fair to have 3 refs, however, life isn't fair. And I'm sure the refs are doing as great a job as they can.
Sorry for the negative comments it's just how I feel.
www.sharkattack744.com
Unread 09-03-2009, 19:17
I'm not really that concerned, i don't think stepping out of the lines or taking the box off the floor should really warrant a penalty. I was just commenting on the fact that if they are going to have these rules that they should be policed correctly. I think that, for the most part, the refs have been doing an awesome job this year.
Unread 10-03-2009, 15:46
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is online now
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Does anyone know how long the tether that holds the tongs is and where it is attached to the fueling station.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 10-03-2009, 16:06
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
At the Boston Regional, most of the penalties called were on the Payload Specialists. When I was coaching the drive team, we always went over the golden PS Rules:
  • Use the tongs for balls not in a tote.
  • Don't stick your had through the Plexiglas.
  • Use your seat belt.
  • Don't pick up the totes.
  • Don't throw the Empty Cells over the wall.
  • Stay inside your box.
  • Don't touch the Super Cell until 20 seconds left.
We were penalty-free in Boston. Does anyone see something I missed?
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 10-03-2009, 16:13
rjamesjr's Avatar
rjamesjr rjamesjr is offline
FRC #2165
rjamesjr is an unknown quantity at this point
At the Oklahoma Regional you could use your hands to grab moon rocks as long as your hand did not pass the plane of the alliance wall. The tongs can be used as long as they do not go outside of the airlock.
Unread 10-03-2009, 16:29
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
At Buckeye in the SF's I saw an HP show the ref the empty cell grab the super cell and then throw both into the crater one after the other. No Penalty because the ref was watching the field.
I agree, too few refs this year.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 10-03-2009, 16:30
srfrchick691's Avatar
srfrchick691 srfrchick691 is offline
AKA: Katrina
FRC #1388 (Eagle robotics)
Team Role: Human Player
srfrchick691 is an unknown quantity at this point
Send a message via AIM to srfrchick691
As a human player, a few more things i noticed being called were:
Sticking hands over the plexi glass wall at the corner fueling stations... It happens mostly during atonomous when you are dropping them right over the wall... Your hand cant cross the plane of the wall.
Second one has to do with touching the ball before buzzer... Our announcer would say. Three... two... one... go... and then about two seconds later the actual buzzer would start. A penalty was received if you touched the balls before the "official" buzzer.
Lastly. While using the tongs. Make sure you pick it up a fair amount off the ground. I got a penalty called for not bringing it up far enough off the ground.
As far at the tether for the tongs goes... It is just long enough to reach the airlock... At our regional (San diego), the tongs wouldnt even reach out far enough to get a penalty.
Unread 10-03-2009, 16:37
President, VEX Robotics, Inc.
This is how it was called at Midwest and Kettering District:
1. Must use tongs to pick up the moon rocks, empty cells, and super cells from the fueling station floor or airlock floor.
2. Can put rocks/cells into the fueling station and use your hands to push them out the airlock as long as you do not break the plane of the alliance wall with your hands. There is a Q & A about this clarifying the rule that you must use the tongs to pick up but not to push out. we use the roll out method at Midwest a lot!
3. Don't even think about touching the super cell until to 20 second sound is made. even if you do not put it on the crater you will get the double penalty.
4. You could not dump the bin into the fueling station. The bin must stay on the floor.
at both events, I specifically asked about the rolling on the floor to make sure the refs knew the Q & A. I will look it up and attach it here in a minute.
EDIT: Found it and it is really clear: http://forums.usfirst.org/showthread.php?t=11987
Paul
Unread 10-03-2009, 16:40
rjamesjr's Avatar
FRC #2165
I checked the rules and we were supposed to use the tongs to pick up the moon rocks (<G40>). I guess the refs missed that one.
Human Player WhiteShadow1474 General Forum 33 11-01-2009 12:07
Human Player Joe_Widen General Forum 62 24-04-2006 21:18
Human Player xxlshortys General Forum 17 20-04-2003 19:02
human player mattshuert OCCRA 2 05-11-2002 23:10
Human Player Steve Yasick Off-Season Events 1 09-10-2001 19:49
